Welding shocks tabs to 14BFF
Discussion in 'The Garage' started by spearchucker, Apr 21, 2004.
  1. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I bought some shock mounts from Echobit some time ago and need to get them welded to my 14BFF. I was wondering if the heated generated from the welding will cause any internal damage to my fully assembled axle.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not unless you intend on making your shock mounts from 3/4" thick steel and welding at 300 amps. /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
    Just kidding. I doubt that it'll hurt anything. Just weld and you should be fine.
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    If you are worried about heat warp (a resonable concern) just weld an inch at a time and alternate sides between passes. Are you using a Mig or an Arc?
  4. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    /forums/images/graemlins/dunno.gif I'm not a welder so I'm paying someone to do it and I don't know what he uses, I think he said he uses a stick welder. I was mainly worried about the seals.
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Seals are pretty far from where shock mounts would be welded on a 14 bolt.
  6. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    Just checking. Better to be safe than sorry. Thanks all. /forums/images/graemlins/waytogo.gif
  7. heavy4x4
    Aug 28, 2002
    3,270
    Absolutely.
    Make sure the weldor knows what he's doing. Last thing you want is for some guy to burn through an axle tube just because he's careless/doesn't know better.
  8. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
  9. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    He's got 30+ yrs experience. But the main reason I chose him is because he's done countless Chevy frame crack repairs/weld on braces (the main job I need done) so I assume he knows what he's doing.
  10. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    i welded on mine for the shock mounts, after buying the MOO kit for the lowers and finding out i would have to reroute my brake lines i took 2" flatbar 1/4 thick and welded them on. The piece was 7"s long, i welded in one place them heated the rest up with a torch and beat it around the axle tube then welded all the seams, worked great and cost about 5 bucks /forums/images/graemlins/thumb.gif
  11. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Make sure the welding dude puts his ground cable directly on the shock tabs before welding. I get plenty paranoid welding on diff's...the last thing I want is any sort of current flowing through bearing races. I've actually seen ground cables attached to lug nuts which is a guaranteed way to mess up all the bearings (depending on where exactly you're welding).
    Rene
  12. k2-k5
    k2-k5 1/2 ton status
    Sep 30, 2003
    285
    Vancouver, WA
    I would still worry about the bearings. Depends where you put the ground I guess. I don't think heat will be a concern.
  13. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    That was my point...
    I've had to replace bearings that have had welding current run through them (at work).
    Rene
  14. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    I'll make a note to check that when he comes over. /forums/images/graemlins/thumb.gif /forums/images/graemlins/deal.gif
  15. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Don't forget to drain the oil /forums/images/graemlins/waytogo.gif
    14FF's have nice ribs to clamp the ground to...that is what I used.
