Welding spider gears...Will it hold up?
Discussion in 'The Garage' started by Ben B., Oct 18, 2006.
  1. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    Like it says.
    Whenever I get my van...Instead of spending mucho dollars on a locker it'd be nice to get my rear end welded up.
    I've heard alot about welded rear ends not holding up though..so I dunno.
    Any insight?
    It being a G20 van I'm assuming it's a 3/4 ton rearend?
    So it's probably a 14 bolt SF.
    I know for a fact it has no form of limited slip or posi, she's totally open.
  2. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Better off spooling it IMHO.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    g20's only have 10 bolts from what ive seen...5 lug at that. i wouldnt weld a 10 bolt...
  4. Ben B.
    Sep 1, 2005
    352
    Central PA
    Might find a posi 14 bolt sf to put under it then.
    It'll be the same procedure as doing the swap to a K5 right?
  5. diesel4me
    Jul 24, 2003
    17,546
    936
    Massachussetts
    not needed..
    I would definately NOT weld it!...it wont steer for S***,and you'll bust an axle on the street most likely--not to mention scrub the tread off the inside tire each time you turn a corner!..
    Most G-20 "3/4 ton" vans are still 5 lug,and have the same 10 bolt axle as a half ton,only the wheel bearings and brakes are a bit bigger....not something thats real rugged IMO--you can find posi's and limited slip diffs used in boneyards,or swap in a 14 bolt--I think the 1 ton vans had different spring pad spacing,I'm not sure they had 14 bolt SF's in vans,I'm thinking only 1 tons had a FF one available..if you swap in an 8 lug rear,you'll have to carry 2 spare tires with both lug patterns..it's no picnic making any 2wd chevy truck or van 8 lugs up front--you have to just about swap the entire front end in-- "A" frames,springs,ball joints and many other parts are different!..
    I had no trouble getting around in my G-10 in the winter--all the weight of the plywood paneling,carpet,bed,and other camping stuff gave it plenty of traction..I don't recall ever having to get it towed out of a snowbank or getting stuck in it--and its an open diff!...:crazy:
