welding spiders?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by hd-10, Mar 10, 2004.
  1. hd-10
    hd-10 1/2 ton status
    Jan 31, 2004
    188
    lemoore, ca
    i read the article on the welding the spiders for the 14 bolt. has anyone else done it to there's and if so how do you feel about it? i am thinking about doing it to mine for now so i can save up for a dana 60 and then get the locker for the rear? let me know thanks /forums/images/graemlins/peace.gif
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
  3. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Are you going to be driving it on the street very much? That's the big factor to consider when welding spiders. I have the spiders (and carrier) welded on my piddly little 12 bolt, but I never drive my K5 on the road anymore. You won't have to worry about breakage so much on a 14-bolt, but you will have to worry about tire wear. Welding is good, though. I like mine. If your truck will not see much or any street usage, I would just stick with the welded spiders and not blow the money on a locker at a later date.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    don't do it like the article. they will wear out and the spiders can crack. If you weld it weld it into a full ball mini spool, or even a mini spool and then to the carrier for the most strength.
    I have the spiders like article and I am going to reweld them into a mini spool.
    Harley
  5. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I agree, mine is welded like that and it is holding up fine. Can't say that about my BFG's though. /forums/images/graemlins/thinking.gif
  6. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    I welded 75-K5's and used 6013's on the gears to get in between the crevices then used Nickel 99 rods to weld the cast iron carrier to the gears. seems to be working well...
    NITRO
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I saw an add in my latest peterson's 4Wheel for drivetrain direct that had mini spools of a 14FF. It had a picture of it and it did have the full X pin design (4 ends).
  8. hd-10
    Jan 31, 2004
    188
    lemoore, ca
    it takes me to and from work everyday about 14 mile round trip then the rest is offroad so i think that it should be a good choice. do think so?
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have driven mine as a DD for over a year with it welded and no problems beside tire wear and turning radius. Mine sees 90% street duty. I have at least 8,000 miles on the clock with it welded. Sounds like a good choice to me.
    Harley
  10. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    You must have a large tire budget then /forums/images/graemlins/eek.gif
  11. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Read my reply to this post. It kinda urned into a mini write up on how to weld the 14b Jethro style. /forums/images/graemlins/woot.gif
    Clicky
  12. hd-10
    Jan 31, 2004
    188
    lemoore, ca
    good article lots of good info but i have the 9.5" and i beleive that was the ff 10.5" but for the most part it should be the same way right? also were are located at and how far from lemoore?
  13. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    Well, you didn't say that. /forums/images/graemlins/rolleyes.gif My welded 9.5" lasted about 2 months before the spiders exploded. Then, I installed a Detroit. /forums/images/graemlins/thumb.gif Luckily, nothing else was damaged in the breakage. Hopefully, you will be as fortunate.
  14. bajaviking
    Apr 10, 2002
    752
    Baja
    Did you weld your spiders to the carrier or did you only weld the spiders together. As mentioned before only welding the spiders will not last, my spiders and carrier is welded into one big blop of metal and it is still holding up just fine.
