welding spidersin 12 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by random, Jun 12, 2002.
  1. random
    random Registered Member
    Jun 12, 2002
    13
    maine
    welding spiders in 12 bolt for mud racin only . any tips would help
  2. 350S10NJ
    350S10NJ Registered Member
    May 16, 2002
    32
    Southern New Jersey, USA
    Look HERE should be the same way 12 or 10 bolt too
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    We welded mine while it was still under the truck. We pulled the cover and rotated it til you could see the first opening in the carrier. Then we filled in the corners where the spiders meshed together. We repeated this process at all four corners at that opening and the other opening...
    It held together great and had no problems with it!
  4. Sinful_Nature
    Sinful_Nature Registered Member
    Jun 14, 2002
    90
    Raymond, NH
    I'm thinking of welding my 10-bolt for temp fix while I prepare my 14-bolt. Anyone out there that has welded a 10-bolt? Any comments? Good...bad?
    Thanks for the feedback.
    ~ Russ
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    I imagine welding a 10 bolt would be pretty much the same as wleding a 12.. If it is temporary til you get your 14 finish, I would say go for it!
