Welding spiter gears?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by newbe73, Apr 7, 2002.
  1. newbe73
    newbe73 Registered Member
    Mar 14, 2002
    58
    SD
    ok you guys, i saw that mod on this web site where it teaches you how to weld your 14 bolt and give it locked differentials. well it got me to thinking and i want to do that to my blazer. but i have never hurd of 14 bolt . i think that mine is 12 i got 1/2 tone axle and 6 lugs on each side so i guess me real question is will that welding work on mine and will i use the same welding spots and stuff , thanks if you guys can get back to me.
  2. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    the 12 bolt carrier does not disassemble the way a 14 bolt does to my understanding, therefoe you are stuck with welding the spiders to the carrier.
    John
  3. newbe73
    Mar 14, 2002
    58
    SD
    are you shure how come noone responds
  4. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I'm pretty sure chevyracing nailed it on the nose. Once you do it, you have to replace the spiders and the carrier to go back to open if you dont like it. Its also an issue of the c-clip style axle that your dealing with on the 12 bolt as opposed to the full floating axle bolted on at the hub on a 14 bolt.
  5. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
