welding the transmission case
Discussion in 'The Garage' started by bigjblazer, Oct 12, 2004.
  1. bigjblazer
    bigjblazer Registered Member
    Apr 9, 2002
    89
    Atlanta, GA
    I have a TH350 with a crack in the case, its fairly small and about 5 inches long, can I weld the crack and keep all the fluid in? The trans was rebuilt just 5000 miles ago, so I'd like to try and save it. Thanks
    -Justin
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    do you have a pic? also bet the crack is longer then 5 inches. i would just grind a V and weld it up though.
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I'd lay 10-1 odds that if you weld it the weld will A) suck and B) cause even more cracking. Cast aluminum is a complete slut to weld, and it is somewhat porous so the weld will be contaminated with ATF as well.
    Even if you could get it clean enough, and you managed not to melt down a nearby seal the case will likely crack even worse due to the rapid expansion caused by welding. The shape of the tranny case does not lend itself well to expansion and contraction caused by the welding.
    If it were me I'd find another case and swap all the guts over.
    Rene
  4. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Rene
    Yuppers, just like Rene said, cast aluminum is tough to weld. You need to have it under the proper heat conditions, just like cast iron. That means heating it up, keeping it up( /forums/images/graemlins/blush.gif ), and slowly cooling it.
    Either a new case, or JB weld if that isn't a posibility.
  5. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I agree with the below, so I wont type it again. /forums/images/graemlins/grin.gif
    Rene
  6. bigjblazer
    Apr 9, 2002
    89
    Atlanta, GA
    Thanks guys, thats just what I was lookin for. So now, anyone got a th-350 layin around?
