welding to axle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by one, Oct 13, 2002.
  1. one
    one Registered Member
    Aug 31, 2002
    28
    redwood city california usa
    I'm welding new shock mounts to my rear axle on my k5. What's the procedure? Do I need to brace it to stop warpage? drain diff. oil? Any advice welcomed!
    Thanks!
  2. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    If you're worried, don't be but to ease your mind weld about a inch then let it cool, clean area and contiune same until you're done. There is a lot of steel and being a round surface it isn't prone to warpage like a flat surface. Good luck
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Like LK said, just weld it how your comfortable. I just laid it down all at once. The tubes are heavy enough, your not going to warp it welding on it. The heavy tubes also act as a heat sink so the oil should be fine.
