welding to the spring?
Discussion in 'The Garage' started by BranndonC, Feb 16, 2006.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    would it be bad to weld to the top of my rear springs? I can rig up my ebrake setup if i can just weld a 1 inch by the width of the spring pack piece of metal to it. would it weaken anything?
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    If it's the main leaf...DO NOT touch it with a welder. I wouldn't weld on any of the leafs though. Welding would seriously weaken the spring...basically wouldn't be a spring anymore right were the weld was.
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    k, i'll find another way, thanks for the quick responce
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    could you possible make a braket that slides over the Ubolt and is held on clamped between the nut and the spring plate? Not sure what you are thinking of but that is close to the spring and should give it enough distance to allow for proper movement of the arm.
    Ira
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I would weld on any leaf other than the main leaf, but only at the end. Anything that supports a load, I would just leave alone. I'd look into the clamp setup like he mentioned. I'd like to see a drawing of what you're brewing for an e-brake though.
  6. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    it was cheezy at best... not worth showing anyone lol
  7. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    kids right
    no no and no
    dawg is right
    bolted bracket is ok
