Welding\Winch?
Discussion in 'The Garage' started by OffRoader93, Oct 27, 2003.
  1. OffRoader93
    OffRoader93 1/2 ton status
    Nov 30, 2002
    262
    Welding\\Winch?
    Will it hurt the electric motor in the winch if I tack welded the mounting bolts for the winch to the bumper? This is so it doesn't get stolen. Thanks for any help.
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Re: Welding\\Winch?
    Nope, just ground at the bumper, not on the motor. /forums/images/graemlins/grin.gif
  3. hoosierk3500
    hoosierk3500 Registered Member
    Jun 5, 2001
    44
    Huntington,Indiana
    Re: Welding\\Winch?
    I'll have to disaree with Don on this one.Welding on bolts will make them brittle.Warn's mounting inst. say to weld a small channel or angle over the head of the bolts.Hope this helps. Jason84k3500 /forums/images/graemlins/truck.gif85k2500 /forums/images/graemlins/burb.gif
  4. chubbybob
    chubbybob 1/2 ton status
    Oct 18, 2002
    730
    Re: Welding\\Winch?
    if you are talking about it hurting the electical system in the winch. it will not just make sure the power cable is unhooked and ground it to the bumper like was said above.
  5. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Re: Welding\\Winch?
    I wouldn't weld the bolts on. If you can find a source for grade 8 carriage bolts I'd bolt it on with them and then weld a piece of channel over the nut end. Otherwise, I'd weld channel over both ends of a regular bolt.
    As long as you have the positive end of the motor isolated it won't care if you weld on it.
  6. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Re: Welding\\Winch?
    Just torque them to 84392234589.2 ft. lbs. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Seriously though go with the channel over the heads.
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Welding\\Winch?
    I also believe winch manufactures will void warranty work if the mounting bolts are welded.
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: Welding\\Winch?
    if you weld the bolts it will void the warn warranty (if its a warn) take some angle iron and weld it over the bolts so it kinda looks like a tent over the bolts then if you need to get them off just grind them off /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  9. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Re: Welding\\Winch?
    ...and IIRC if it is a Ramsey that is more than a couple years old it is in fact case grounded, and their is the potential for electrical damage. Either way make some sort of hat for the bolts, don't weld directly to them.
