Welding with a oxyacetylene torch
Discussion in 'The Garage' started by MrArmyAnt, May 3, 2006.
  1. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    Have a holw in the tailgate of a blazer. picked up some light (not really light but quite a bit) reading material on welding, and most say oxyacetylene torch should be the first purchase for all it can do. Any comments? I know an exhaust guy who said he'd teach me to weld this way, I may take him up on it. Anyway what torch is recomended? I'd rather go nicer than crappy. :). Also if anyone in the DFW area know gass suppliers let me know.
  2. dyeager535
    26,976
    For repairing sheet metal (and not being a welder) it looks to me like TIG is the way to go.
    I know it can be done with MIG, but anything that imparts a large amount of heat to the base metal is going to be *harder* to deal with than say a TIG, which to my understanding is very precise.
    Sheet metal warps very easily with heat, I would think an oxyacetylene torch would be a bad choice for sheet metal repair?
    http://classicbroncos.com/homemade-welder.shtml I like home built stuff. :)
  3. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    i don't know much about torch welding but i know they've done it for a long time. mig is fine for sheetmetal as well. that's how i bobbed and shortened my bed. i use a miller 210. just have to go one tack weld at a time, that way the heat won't build up.
  4. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
    i love tig the most. but i dont think that is ideal. mig is good for all around and it is quick. oxy act is good but you'll burn holes and heat affect zone will be huge, but you can cut large things with it.
    the best thing to do is probably get both. that way you can do sheet metal(with mig) and larger things(oxy ac.)
    tig would be too expensive and not ideal for learning as a first welder. or you can learn with tig, so when you do mig for the first time you'll b a master.
    oh and i'm not saying that you cant weld sheet metal with oxy act. its just pretty darn difficult.
    also it depends how much you have to spend..like everyone will say, buy the best with the money you've got.
  5. MrArmyAnt
    Dec 29, 2004
    662
    I just ordered a 12hp honda motor, going to use it for a compressor, generator, and alternator for air, power, and welding. Seems that people have had good results making tig welders that way. And I'll buy a torch to make the frame for all of it.
  6. PeteH
    Mar 26, 2003
    498
    San Jose
    make a tig welder?
    or you talking bout making an arc/stick welder?
  7. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    A MIG welder is by far the easiest to use for sheet metal work, especially if you don't have much experience welding.
  8. MrArmyAnt
    Dec 29, 2004
    662
    It said tig on the site...
  9. PeteH
    Mar 26, 2003
    498
    San Jose
    which site? if they show how to make one thad be cool.
  10. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Quote of this thread. You can do sheetmetal work with any welder if you have the required experience. A MIG is the least demanding for this application.
  11. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    at the shop i used to work at, we used torch welding for things like cast iron. like say if a block was dropped and broke an ear off. we would "weld" a new one back on. basically we added all new material. but we used a mig for most of your "welding" needs.
  12. MrArmyAnt
    Dec 29, 2004
    662
    Actually its the post right after mine. http://classicbroncos.com/homemade-welder.shtml I googled the topic and returned a lot of results using mustang alternators and such. A lot also ran compressors and generators off the gas or diesel motor (i bid on a gas, hopefully ill loose and will do diesel) on a 13 hp motor.
  13. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    To answer your question of what brand oxy acet gear to pick up, Victor all the way. A torch is probably the most versatile tool. It cuts and glues. The other types of welders just glue. Monkeys can use mig guns. It takes skill and PRACTICE to handle gas and TIG welding.
  14. MrArmyAnt
    Dec 29, 2004
    662
    Sounds good. I see you're in Denton. Any reomended supply stores/vendors?
  15. tx_sub
    Mar 5, 2004
    548
    Denton, TEXAS
    There are a few up here, but I've not been to them. There are several in the Dallas area. I bought some stuff from one on Singleton East of Loop 12 when I worked down there. Dont' recall the name. You may find a better deal online. I've gotten good deals online from cyberweld.com
    Froogle.com is your friend. Good luck.
  16. MrArmyAnt
    Dec 29, 2004
    662
    I love froogle. Only thing is where do I get the gasses filled?
  17. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    Master the gas. Once mastered you will understand why I said this.
  18. MrArmyAnt
    Dec 29, 2004
    662
    So gas it is. Still need a good compressor/lawn mower engine seup though. Let's hope gas won't damage the hole on the tailgate i have to fix too much.
  19. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Gas welding the tailgate which is 22 guage at best is most likely going to result in either a bigger hole, or some much distortion from the ehat you'll kick yourself. A small MIG machine is best.
    TIG actually puts more heat into the material than MIG does.
    Rene
  20. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I think gas welding for bodywork would take alot of skill and practice. The process is slower and therefore more heat will transfer and warp the panels.
