welding with straight argon...
Discussion in 'The Garage' started by sled_dog, Oct 22, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I forget what happens when you weld with straight argon. Usually I use a 75/25 mix of argon and CO2, but I just went to lay down a simple tack and realized I am completely out of 75/25(2 tanks on 2 welders, both empty at the same time :mad: ). So I grabbed the little bottle of straight Argon dad had for aluminum welding and laid the beads I needed to. Sounded slightly different then I'm used to, but I've also been practicing welding a lot and am welding much better then I used to.
    So is there any adverse effect of running straight argon when welding mild steel?
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    I don't think it'd be a problem. Can't say I've ever used straight argon for MIG steel though. Usually run 92/8 at work though.
    Rene
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Welds all look fine, plenty of penetration, so I guess all is fine. Off to mount the shackles finally and get an axle under the S-Dime :D
  4. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    co2 or helium is used to speed up the weld. so you can lay a bead down a little faster. runs a little hotter with co2 or helium. i run straight argon and mild steel, aluminum, and stainless. its just a little slower. and not as hot.
