Well a th400 NP205 adapter work on a Th350?
Discussion in 'The Garage' started by adamforsythe, Jul 1, 2006.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Will a Th400 Np205 adapter work for a Th350?
    Adam
  2. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    No, the trans side shape and bolt pattern are completely different. The TH350 has a 4 bolt, square pattern whereas the TH400 is octogon with 6 bolts.
    Fyi, if you've found one the TH400 version adapter is pretty valuable. :wink1:
  3. denny_deer
    denny_deer Registered Member
    Jun 3, 2006
    18
    provo, utah
    Thats correct they are different. If you need a 350 to 205 adapter i've got one i'd be wiling to trade for a th400 to 205 adapter.
    if interested get back to me
  4. bgreen
    bgreen 1/2 ton status
    Jun 12, 2004
    167
    Alaska
    just incase someone searches, the th-400 tailhousing bolt pattern isnt symetrical. You cannot just turn the adapter upside down to flip a t-case.
    Here is a file I made when I modified my TH-400 adapter to flip my 203. One color is the stock holes, the other is the upside down holes. All based off a Zero at the center of the rabbit fit.
