Well, bought a BBC..... lots of pics
Discussion in 'The Garage' started by white-rhyno, Jan 5, 2005.
  1. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    Well,
    I never thought i would have a BBC, but for a complete 375hp 454 out of a 71 chevelle for 500 bucks, i couldnt say no. It ran when my boss took it out of the car, had it hot tanked and checked for cracks, all good. Its a virgin block, no work has been done to it. Still unsure if i want to just hone it and throw it back together, or go all out. Either way im sick of this "not having enough power". Ill toss around some ideas and get it in later this year.
    There are allot of you guys with BBC's out there, what do you think???
    Here are way to many pics of it......
  2. seattlek5
    seattlek5 1/2 ton status
    Feb 23, 2001
    311
    ...with one hand on the bender.
    Very nice. I'm jealous:D Roller cam too!
  3. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    very nice :D hope to have one soon to :cool1:
  4. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I'm Jealous!
  5. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I think with those closed chamber heads you better buy some pistons with lower compression or you'll be needing to run race gas :blush:
    otherwise...good score:laugh:
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i would have passed on it personally
    i would never buy an apart engine, ever,
    i would have put 1/2 or so of that $ into a 350 or 400
    good luck with it
  7. white-rhyno
    Jan 27, 2002
    942
    the motor that is in my truck currently was kinda the same deal, got a free short block and some cheap tbi heads. At least then you know exactly whats in there. And putting 250 bucks into a small block dont get ya very far. But to each his own.
  8. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Sounds like a good deal to me. :deal: Did you get all the brackets and such with it? If not, that might set you back another $100 or so.
    Trust me, after you drive it the first time you wont go back to a small block. ;)
  9. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    Nice score
    1. which pistons does it have? If you have a big dome .25 or so you MAY want to swap to an open port head to drop some compression... Depends on that big cam.(I've got some 781s that are fresh with 2.19/1.88s I'd like to swap for a closed chamber).:D
    2. what are the specs on the cam? duration @.050, lift, and L/S. Don't be afraid of big cams in a bb with enough compression, they handle them much better than an sbc. Nice intake too...
    3. I wouln't hessitate buying a dissasembled engine. No suprises. Guess knowing how to put one together makes a diference?
  10. white-rhyno
    Jan 27, 2002
    942
    Exactley, no surprizes...
    As far as the cam specs, i have no idea, ill probably end up giving that away, i dont need that much cam. Its huge. To bed honest with, i can put together a motor from a short block, and put it in, as far as putting it back together correctly, ill let somebody that builds them for a living do that. But thats just me. I have watched and helped put together many motors from scratch, im just not interested in doing it on my own.
    oh wait
    Adv. Duration: 316°/320°
    Gross Lift: .722''/.722''
    RPM Range: 4400-8000
    Lunati 50225 Roller Cam #16446
  11. white-rhyno
    Jan 27, 2002
    942
    well a little more info
    66201-16 CROWER BBC ROLLER LIFTERS $336.95
    EDL-7561
    Intake Manifold, Carbureted, Aluminum, Natural, Dual Plane, Chevy, Big Block, Each
    $231.95
    i think that $500 sounds even better yet
  12. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    The camshaft is VALUABLE! A roller cam will not wear like a flat tappet, I would post the cam, lifters, push rods and valve springs up for sale at speed shops and such. You can probably get 1/3~1/2 of the cost of the motor back.
    FYI - in case you didn't already know or catch it the push rods and valve springs will need to be swapped too. The push rods are shorter and the springs will have too much seat pressure for a regular cam.
  13. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    Seeing they are new in the box, and I don't see any springs on the heads, and the heads still have the light duty 5/16" guideplates id bet this has never been together. The cam and lifters should get you close to ALL of your money back.
    Post them here: http://www.bremertonraceway.com/
    and here: http://members5.boardhost.com/bsaltmayer/
    for a possible local sale, or there's always ebay...
  14. motorheadnelson
    motorheadnelson Registered Member
    Aug 12, 2001
    80
    Fort Mohave AZ
    Wow..That cam would have to go. That's for a light, dragstrip only or serious street machine. Obviously solid rollers. You can still use the lifters, but a cam around .550-.570 lift and advertised duration in the 280 range would give you a more usable range with good torque and power while still making the sound that gets you noticed. Still needs gears, maybe 2200-2500 stall with auto. Keep the LSA 112/114 to keep some bottom end. Needless to say, that's not a towing setup. Just makes a fun toy. If you tow, keep the adv duration around 260/268, use a converter for towing. A loose converter will bake in a hurry. I'm sure you'll get lots of responses.
  15. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Well, if ya ever decide to bump down the compression and go to open chamber heads... let me know. :D I'm in the market for some closed chamber ones. What do ya want for the cam too if you don't use it?
    Good score too. I sold a 396 bored .060 over that needed to be rebuilt again minus heads for $200 cause someone wanted that casting block. I bet I'd know guys over here who'd be all over that block, especially cause it's standard.
    I love big blocks. :cool1:
  16. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Nice work honky. I am sure that Dave or Shannon will help you stick it back together! Dave probably has a pile of BBC stuff sitting around from his old Camaro...:rolleyes:
  17. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    not bad, seeing a motor that is apart has it advantages, heads, cylender walls, cam condtion, carbon build up ect
    for 500 bucks you did fine for a one that has not been bored, I have had, bought, and sold a bunch of big blocks already. Sold from 200.00 to 1500.00, and bought from 200.00 to 600.00. Did you get brackets, pulleys and acc too? If so you did real good.
    my best gold mine so far is an ls6 big block, you will love the difference with a big block, not to mention there is just something about seeing one under the hood, makes people giddy and smile like little kids!:saweet:
    once ya go big block ya never go back! " unless you blow it":ignore:
    just get some some work done to get the heads to flow, throw a cam in the bad boy and enjoy the rumble!:D
  18. diesel4me
    Jul 24, 2003
    17,537
    921
    Massachussetts
    What kind of gun did you use??
    500 BUCKS!!--I'd say you got a good deal on it!--as other said,selling off the roller cam you dont need will help offset the cost of the rest of the motor..
    I dont usually buy engines that are dissasembled either,but one advantage is you can inspect everything for cracks,wear,and any other defects--all the engines I've bought assembled and running always seem to end up apart for something anyway,like a timing chain or oil pump,or head gaskets---one disadvantage is sometimes a few hard to find brackets or parts get lost in the shuffle when someone else takes it apart,and you have to hunt down that elusive part--
    But thats small potatoes when you get the complete motor for a reasonable price!--as for buying a big block anywhere,apart or assembled,you wont see many for any less than 500 around here--at swap meets I see 454 bare blocks selling for nearly that much--the last 454 I saw at a swap meet in CT was going for 800 bucks complete,and it looked like it was at the bottom of the atlantic ocean,all crusty and rusty--the seller said"it turns over!"--looked like a basket case to me!(and it was the ONLY one there as far as I could see)....:frown1: --Big blocks arent really THAT rare,but finding one for less than a grand for a runner is pretty hard to do nowadays--they arent making any more of the older style ones(pre-86) unless GM still has the "targetmaster" ones available..:crazy:
  19. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Get a nice camshaft and I'd slap it back together. No idea what compression that is, me I'd just put a little race gas in and top her off with 93 :D
  20. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Looks like you did well. Nice Score!
