well boys i think i may of found my lil problem...
Discussion in 'The Garage' started by chvymudin3388, Feb 4, 2007.
  1. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    no wonder i got bad blow by, i ran a comphression test and all cylinders read in a good 120 psi except for nubmer 3... it reads like 10 if that. so what you guys think? washed out the side of the piston? broke ring? hole in the piston?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Only way to find out is to take it back apart. :( Assuming that the valves on that cylinder are closing... ;)
  3. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Ya pull the valve cover and make sure the valves are opening and closing fully.
  4. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    x2:rolleyes:
  5. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Yeah, might just be a valve spring..........:wink1:
  6. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    120psi is good compression? does compression vary depending on engine compression ratio or piston stroke? or what? not to hijack...
  7. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Depends on a lot of things from cam overlap, cam timing, static CR, and cranking speed (just to name a few variables)
    Rene
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Altitude also affects measured compression. As you gain elevation, atmospheric pressure drops. Less air going into the cylinder means less pressure when the piston tops out. :(
  9. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    ty gents...
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    For a ball park measurement at sea level, compression should be somewhere around 14.7 (atmospheric pressure at sea level) times the compression ratio. So for an 8.5:1 compression ratio, you'll see somewhere around 14.7*8.5=124.95 PSI. It's just a ballpark figure, as valve timing affects it, but it should get you within 10 PSI or so on a stock, tight engine.
    Cam selection plays a role and more radical cams will let some pressure bleed off at cranking speeds due to longer valve overlap duration.
  11. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    well thats what i dont get is it seems to idle fine, and if it was a spring wouldnt i t like misfire or backfire or something? plus its building pressure in my motor enough to pop out the PCV out of the valve cover and no its not plugged.
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Most likely. The blowby problem really points to something bad wrong inside the engine. :( Pressure is getting past the combustion champer and pressurizing the crankcase. A stuck valve wouldn't cause that. :(
  13. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    see thats why i dont think its a valve. thats why i think it a ring or piston
