Well, finally got the two cucvs to run. more ??ANYONE PLEASE HELP
Discussion in '1982-Present GM Diesel' started by 84CUCV, May 14, 2006.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Not sure what the chance is, but it looks like the GM sold me bad relays. Got a cheap one for 20 bucks from a part store and they both start up now. This is what i dont get. I hear a click when i turn the key on and no other ones after that. 12v at the top and then out the bottom, but it never cycles down. I thought that 12v in the top cycle down and 0 out the bottom to know that the glow plugs are off. From what the metter said 12v out the bottom all the time. So i think my gp are staying on. So now what the heck could it be? this must be my 100th post about my starting problems. i think i am getting closer.....
    as aways any help would be great. thx!!:bow::bow:
  2. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    anyone i need this done..........
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    this is the last thing i need to do and i can put the k5 back on the road. thx
  4. ccatlett1984
    ccatlett1984 1/2 ton status
    May 1, 2005
    161
    michigan
    you need to get the GP controller on a manual switch. the small (blue if I remember correctly, I'll have to check mine when I get off of work) wire attached to the small blade of the relay just needs to be connected to a momentary on switch, then take the other wire off of the switch and run it to a good ground.
    then all you have to do is hold the button in as long as the wait light is on, just remember to let go of the button before you crank the engine. the extra voltage from the alternator charging the batteries can be enough to fry GP's.
    you should come over to our MV forum. www.steelsoldiers.com
    we cater to all kinds of Military Vehicles, have special sections for different era trucks (including the CUCV) and membership is free.
  5. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    I thought that's what the glow plug controller was for:confused::confused::confused:
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yeah but sometimes it doesn't work and it's easier to bypass it than fix it.
    I had the same proteblem and if it's a pre 84 I definitely do that. 84 and up the system is not too bad and I would probably try and fix it.
    Now on a CUCV it's even worse because of the 24/12volt issues so I would definitely go manual switch.
