Well, I bought my first diesel
Discussion in '1982-Present GM Diesel' started by Russell, Apr 4, 2007.
  1. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    1982 6.2L K5 :) Red block, 50 000 miles, and runs like a top! I've never heard a 6.2L sound as healthy as this one does, doesn't even have any blowby!
    Time for a set of 6.5L heads and a turbo kit ;)
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Where pics and a sound clip already??
    Congrats! :thumb:
  3. Russell
    Jun 23, 2000
    7,923
    333
    I'll post a sound clip after I drag it home tommorow, 700r4 is blown up, like usual, lol
    Plan on putting an NV4500 in to replace the slushbox ASAP. At the moment, it appears to be a bad torque converter causing the problem...
  4. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Red block? As in color or is it supposed to be some type of enhancement?:confused:
    Pics! Pics!:D:D
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    first 2 years were red
  6. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    i think just the first year - mine's a stock '83 and not red.
  7. Russell
    Jun 23, 2000
    7,923
    333
    Yep, I do believe it is a single year engine too :)
  8. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    My mistake, I know I had the 82 and it was red and I thought 83 was the same since they had the same controler setup too. But then again even the injectors for the 82 was differen from all the rest.
    :D
  9. Russell
    Jun 23, 2000
    7,923
    333
    So, as far as bolting a 6.5L turbo on goes -- Can I use my stock heads / injectors etc?
    I've got a complete 93 6.5L TD for parts sitting in the back yard :)
  10. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Yeah, red block color and coarse thread injectors for '82 only. Some guys swear the '82 block is stronger casting too...
    Rene
  11. Russell
    Jun 23, 2000
    7,923
    333
    Is there any reason why the stock 82 injectors wouldn't work with an 93 turbo? Or does a guy have to change the heads to 6.5 heads to bolt the turbo intake / exhaust manifolds on?
  12. Russell
    Jun 23, 2000
    7,923
    333
    Ok, so according to my reading, it looks like everything will bolt straight up less turbo to injector clearance issues.
    However, I was reading a post on thedieselpage.com that claimed the 82's injectors are shorter than the newer ones, so that might not even be a problem for me...
    We'll see how it goes, if it is just a matter of hooking up oil pressure and return lines, and getting exhaust done, I'll probally get this thing turboed before I ever hit the road with it, lol
    I've got a buddy who is big into these 6.xL diesels, and I'm sure he'd leap at the opportunity to help me turbo it, esspecially since he'll be getting the cash to buy all the parts, LOL
  13. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    The 82 injectors are coarse threads so they don't interchange with the rest.
    I believe the Van injectors are short, maybe the 82 ones too..
  14. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    I've learned alot at gm-diesel.com (search posts by hjacobson). The 82 block (599) has a higher mag(?) content than later years making it stronger, and the injectors were shorter with course threads. You can use newer heads on the 599 block to keep the injectors a common part.
  15. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I thought the 599 was 93 not 82.
    I have a 599 block from an AMG hummer. :D
    And I know the 82 has higher magnesium content, but I thought also higher nickel which usually makes a good block.
  16. bear76
    Oct 16, 2005
    1,065
    here
    Yes, nickel is what I ment to say, sorry. I was under impression that the 82 was a 599 and used in the later years for a couple of years as well (hence your 92). I am going off of memeroy here, so I could be wrong. If I need to know for myself I would research at the other place, I'm still learning.
  17. Russell
    Jun 23, 2000
    7,923
    333
    Those 599 blocks can be punched out to make it a 6.5L, but I don't think I'm going to be going quite that deep into it yet, lol
    This engine has about 50 000 some miles on it (less actually), so if I can use my stock IP + injectors with the turbo, I'd think it'd be best to do that. The donor truck has like 250 000 miles on it, lol
  18. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    599 block was 92 and 93. I can't recall the casting number on the '82 block...only that it has higher nickel content making it stronger. The '82 block can't be bored to 6.5L bore size...but the 599 block can.
    Rene
  19. Russell
    Jun 23, 2000
    7,923
    333
  20. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    That is one thing I like about the 6.2/6.5 and their Ricardo Comet V prechamber setup - they have a nice purr to them, rather than a loud obnoxious clatter (i.e. Cummins 4BT/6BT, 7.3L PowerStroke, etc.). :D
