Well I think I found my Bumpsteer problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by vdubbin86, Jun 2, 2002.
  1. vdubbin86
    vdubbin86 Registered Member
    May 25, 2002
    55
    Alberta, Canada
    I took the truck to the place I used to work and put it up on the lift to check it out. The good part is that my front end is nice and tight. The bad part is my rear leafs are cracked. I think this is what is giving me the bumpsteer, cause I have been noticing lately that it seems to be comming more from the rear than the front. Anyone else have this problem?
    Looks like I'm in the market for some 4" rear lift springs.
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I had the same thing happen with the cracked leafs (both sides mains were cracked) but bumpsteer wasn't much of an issue. Double check your shocks while your in there, that could promote a lot of rear end wander with broken leafs. hows your pitman and steering arm angles?
  3. vdubbin86
    May 25, 2002
    55
    Alberta, Canada
    The angles look fine to me. (untrained eye) But the rear end is what is wandering. The right rear shock is leaking also. So hopefully when I replace the springs and shocks in the rear my problem will go away. Which is ok cause I was planning on replacing the rear springs with 4" lift springs to get rid of the blocks anyway.
    Any reccomendations on shocks that work well with a 4" lift?
  4. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Depends on what you do. The dual purpose guys really like the Rancho 9000's for street and crawling. The street/pre-runner guys like the Doesche techs because they ride soft and they still crawl well. I have ProComp ES3000's all the way around which were stiff on my 33's at low speeds but did well at higher speeds like washboard roads, they dont do well with my 38's now for anything but crawling / freeway speeds are a mess with them. The RS5000s are stiff as well with similar results as the ES3000's. I think we'd all like to get a set of Kings / Fox / Bilsteins so I won't even go there.
    For myself, I'm looking into the Doesche Techs if I can get them as long as the Rancho 9000's... but the 38's might require and external reservoir shock to stay cool enough to be effective and most multishock applications ride too rough for me!
  5. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Same thing caused my problems, tho mine caused more as a horrible, side to side rolling of the cab that wouldn't stop. I think that bumpsteer was there too, but overshadowed by the roll.
