Well it happened again .blew another 10 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bckinblk, Oct 26, 2002.
  1. bckinblk
    bckinblk 1/2 ton status
    Jun 12, 2002
    305
    bristol connecticut
    This is my second axle in 3 years I had 3.42 gears stock when I bought this axle it had 3.73s in it I really like the 3.73s with my 700r4 and 33.s only problem is I blow these 10 bolts up in no time .I am looking for a direct bolt in axle like a 12 or 14 bolt .I know this has been covered many times but I would like to know which year axle will just bolt right in without having to move the spring perches or what will be my best bet with around $400 to work with and what year truck-van axle should I be looking for.thanks in advance for any help I gotta get my k-5 back on the road asap so the easiest most direct bolt in is what I need right now till I can save some $$$ and go 1 ton all around......... /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    If your gonna upgrade go directly to 14FF save time and money /forums/images/graemlins/thumb.gif! IMO Corp12 are not any better than 10 bolts!
    Bill
  3. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    If your lookin for ease of upgrade why not throw in a 6 lug 14 bolt? It should hold up fine to 33's.
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I would go with the 14 Bolt FF. You will need to conver the front to 8 lug and get new rims all around, or carrie 2 spairs. But the 14 Bolt FF is the strongest. Easy way is to find a junk 3/4 ton truck you can buy for a couple hundred bucks, and pull the axles yourself, swap them in your truck. That way you get a matched set of 3/4 ton axles cheap.
  5. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    For a true bolt in look for a 84 and up 3/4 ton pick-up or 'Burb donor axle. If you find a SF 14 you can convert it to 6 lug. The reason to try for 84 and newer is so you get the correct backing plates/E-brake cable setup for your vintage of K5.
    Rene
  6. bckinblk
    Jun 12, 2002
    305
    bristol connecticut
    thanks for the info I found a 1985 2500 in the paper today .Will the pick up spring perches line up with the k-5 springs??
  7. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Yes the perch width and shock mount location is the same for a 3/4 ton and a 1/2 ton...unless the 3/4 ton is 2WD then the shock mounts will typically be too low on the axle tube.
    Rene
