Well it's in.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by i_4x4, Apr 1, 2001.
  1. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    Well it\'s in.
    I finally got my Detroit installed in my 14FF. I ann't wait to try it out on some trails. I barely even notice that it is thier except for the little extra back lash in it. I only got it to pop once at a complete 360 at full lock, when i straighten out to drive away.
    Later Ed
    LET'S ROCK
    Don't follow me you will get STUCK!!
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Re: Well it\'s in.
    Now go see if you can get it stuck. Did you install it yourself?
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails[​IMG]</font color=blue>
    <font color=blue>Wayne</font color=blue>
  3. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    Re: Well it\'s in.
    sweet been thinking of one for my slef how hard are they to put it in if you did yourself if not im sure some has on here os its this question is to anyone
    Bandit
    (Your right i dont understand the jeepthing)
  4. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    Re: Well it\'s in.
    Glad to hear that Ed. Hope everything else is going good! I'll e-mail ya later,
    David 75K5
    http://www.extremeblazer.com
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Re: Well it\'s in.
    Cool!!! You'll love it on the trails except for slippery sidehilling..
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "He who uses a winch...... Is tired of yankin!"
  6. i_4x4
    Feb 20, 2000
    359
    Re: Well it\'s in.
    Bandit,
    It was pretty easy. It took about an hour an half from start to finish. The only real trick is holding the wing nut while unscewing the bolt after it is installed in the case halves. Also check your back lash on your gears before and after, so you get the same wear pattern on your gears. I made it easy and marked the adjustment rings, and backed them off 2 full turns then reinstalled back to where I started. Then rechecked my back lash.
    Later Ed
    LET'S ROCK
