Well that was a simple fix!!!
Discussion in 'Pacific Region' started by blazer88k5, Oct 29, 2002.
  1. blazer88k5
    blazer88k5 1/2 ton status
    Aug 23, 2002
    103
    Modesto, Ca
    Good News.... I dropped the t-case and put in the spacers and NO MORE rumbling noise. A BIG THANKS to Ken and Chaz for letting me what to do. /forums/images/graemlins/thumb.gif
    Truck looks alot better with the lift on! No more "stock" lift /forums/images/graemlins/cool.gif , now I just have to change those funny looking little tires /forums/images/graemlins/confused.gif 33's later this week if fundage permits!!
    Pics tomorrow!!!
    Thanks, Randy
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    sweet...glad ya got everything all fixed..so the next project...1 ton swap! /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  3. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Glad we could help. /forums/images/graemlins/thumb.gif You may want to in the future change out the small spacers and use some solid strips of metal. (6x1.5) What ever the size is to make it a little more solid. I need to do that to mine soon. (i think Superlift makes them) if you don't want to.
    Again glad we could help. /forums/images/graemlins/k5.gif KEN /forums/images/graemlins/usaflag.gif
  4. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    Right on! /forums/images/graemlins/thumb.gif
    You may want to put your t-case in 4wheel to see if it falls outta gear. I had that prob but didn't realize why for months.
    I just recently learned how to adjust my t-case, thanks to 4x4High and some of the other guys!
    /forums/images/graemlins/k5.gif /forums/images/graemlins/rotfl.gif
  5. Chaz88K5
    2,979
    Stockton/Lodi CA
    when i first put the lift on mine and droped the t-case i had the same prob...it was driving me nuts for the longest time then i realized i forgot to adjust it...as soon as i adjusted it worked perfect
  6. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    DO TELL...(adjust? /forums/images/graemlins/confused.gif )
    I thought that you could only drop the t-case not adjust it...
    Thanks. /forums/images/graemlins/k5.gif
  7. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    some trucks don't need it but mine did. I just had to adjust the linkage.
  8. blazer88k5
    Aug 23, 2002
    103
    Modesto, Ca
    You say I might need to adjust the linkage....is there a chance if I drop it out of 2H I won't be able to shift back... or as long as I can shift to 4H and 4L then it's all good?? /forums/images/graemlins/ears.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif
    Thanks, Randy
  9. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    It might drop out of 4hi and 4lo. You could put it back but I had to hold my shifter in gear in order to keep it in 4wheel. It's an easy fix.
    But first try putting it in 4wheel and drive around and go over some bumps or something. If it slides out of 4wheel then you should adjust.
  10. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I had to adjust my t-case for the body lift. It's easy 2 man or woman job. Scott helped me adjust the t-case on my 84. /forums/images/graemlins/thumb.gif
