Well, That Was Disheartening
Discussion in 'The Lounge' started by Resurrection_Joe, Sep 1, 2006.
  1. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    All ethernet connectivity went out on my main box........ poopers
    So I check the other box on the network...... IT'S FINE!?
    No way my magical deathbox can be broked!
    All parts and cables check out.........
    So, wierd........
    The disheatening thing is, I don't know how I fixed it. Somewhere between three restarts and a safe mode along with two modem power cyclings and three router cyclings with an additional router reset, and a foray into Hijack This! it came back on.
    I deleted soemthing fishy in Hijackthis.....
    I cannot recall directly, but it said something about a content filter, and I'll be damned if I'm going to have any sort of filter installed on MY computer.
    So yeah....... I'm supposed to be literate comp wise, and I basically did the comp version of kicking the fender and starting it up a few times to see if the noise would go away.
  2. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    RJ: what if anything do you use for a firewall.
    I knoew Zonealarm and Symantec IS both had anti-tamper protection, such that if something killed or tried to mess with the firewall service, they would lockdown your ethernet connection out of "safety".
    Otherwise .... Standard network troubleshooting
    1) physical link (link lights on both ends)
    2) IP yes / no?
    3) if no ip try manually assigning the ip / if you got an ip, repair connection
    4) get me answers to 1-3 and i'll help ya from there.
  3. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Well it's all better now but......
    I do have Norton Internet Security
    Its started to bog down and screw up right before it went
    1. I had link lights on both sides, the NIC was fine, the router seemed fine
    2. I could not get to the router though it's address, or ping anything (websites, routers, other computers) from my box, The routers set IP's and whatnot were fine. My DSL is PPPoE
    3. I'm sure all the setting were proper, it was just all of a sudden "**** you RJ, no network!
    Anyway, it's back after I messed with it as detailed in the first post
