Well the old 468 had it's time...
Discussion in 'The Garage' started by white_knight, May 25, 2005.
  1. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    The 468 said good bye to us. It took in some water, heads re done...so a new engine is being installed as we speak
    Specs
    It;s a 433 BBC.
    11.3:1 cr
    Childs and Albert hd alum. rods w/ floating pins
    Keith Black diamond-cut pistons smoothed tops for hot spot alleviation
    Msd pro-billet distributor
    2.19/1.88 ss valves
    Lunati .692/.693 solid roller cam and springs
    Crane roller rockers & lifters(mechanical)
    Bbc steel crank
    Fully balanced-race
    radius valve job
    Ported and polished heads-within 1/2 cc
    Cat sfi dampner
    Cat stud girdle
    7/16 hd race pushrods and retainers
    Meziere electric water pump
    Cam button
    Bronze cam gears for billet distributor
    All ARP ss fasteners
    ARP rod bolts
    8+ qt oil pan and moroso pick-up and high volume pump
    7500+ rpm reliable consistently
    roughly 580 hp/575 ft/lbs with single plane manifold
    We changed a few things .
    New roller cam- intake lift .653 , .660 exhaust
    Intake duration 286
    exhaust 292
    and valve springs to go with the cam
    We took off the aluminum rockers and replaced them with cromoly rockers
    Intake has also been changed.
    It will be going to the dyno.
    Fuel injection will be a 4 barrel TBI
    Probably looking at a 200 shot of nitrous.
  2. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    You're truck is going from :D :cool1: to :D :D :cool1: :cool1: :D :D that will be kick butt!
  3. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    holy crap that is a lot of $$$$$$. I know its heavier, but I wonder if a 24v Cummins could have been had for less...
    j
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    aluminum rods? plan on changing those out in a year or two tops eh?
    So why less lift outta the cam? More duration eh? what was the old duration?
    The new one is 286/292 advertised?
    Sounds like it should be a thumper. My 469 BBC is built pretty similar to yours.
    Its around 575+ HP/TQ.. ran a mid 11 @ 118 last summer in my 3380 lb '67 camaro..
  5. white_knight
    Feb 23, 2001
    1,171
    The aluminum rods will be changed at the end of the season.
    We had an opportunity to pick this engine up for about the same it would have cost us to rebuild the old 468....so...we could not turn it down....We do expect it to have a lot more power than the 468....... It was tired......
    I have a feeling I'll need an extra set of undies though :blush:
  6. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    The aluminum rods will be fine longer than that....Just don't lean on them when cold.
    My experiance with stainless fasteners has been bad. They all seemed to loosen up all the time. Is this typical, or just my luck????
  7. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Holy cow!!!!! I NEED a ride in this monster!!!!!:grin:
  8. Storm Trooper
    Nov 24, 2000
    4,640
    Just one comment........
    Sweet :waytogo:
    Gotta love that BB power.
  9. DesertDueler2
    DesertDueler2 1/2 ton status
    Dec 25, 2004
    132
    Chandler, AZ
    A good set of aluminum rods will last 100,000 miles in a dd, and weekenk warrior. I know they do in pontiacs atleast(oliver rods).
    Dan
  10. white_knight
    Feb 23, 2001
    1,171
    I hear a lot of controversy on the aluminum rods. We are going to see how they do this season. They are huge
