Well, the Thumper Operating Room is opening soon... Guess I was due...
Discussion in 'The Garage' started by Thumper, Jun 17, 2002.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    The Canadian salted roads have taken thier toll. Thumpers rear floor cross pan brace just busted near
    the drivers side, and the floor around the second body mount from the rear has rusted thru and let the
    mount push thru the floor. Guess its time for major surgery. I will be doing some surfin of all you guys'
    tech articles on the repair of the floor etc. I have a pickup truck bed floor here that I was going to cut
    to size and weld in but I also just aquired a 3/4 ton Chevy truck for 100.00 without engine tranny
    or t-case, so I am considering using the entire back half of the box to replace mine.
    The pickup truck should be the same right? As far as the cross pan goes? I also need the
    bottom of the upright pillars too. I want to go with the pickup tailgate, but the bottom hinge holes
    are rusted thru on mine.
    Gonna be an undertaking anyways...
    I have a month till the next club run so......
    /forums/images/icons/tongue.gif
    Laters
    Mike
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Have fun dude...it's a big old nasty job!
    Rene
  3. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    The Pickup tail pan is different. It does not have the same mounting points for the body mounts nor does it have mounting for the tailgate. If you plan to run a truck tailgate, you could use it without a problem. I built mine out of 1/4" wall steel, I wrote a tech article on this in the tech forum. Mine worked out pretty good and still holds like a champ.
  4. Richard Haynes
    Richard Haynes Registered Member
    Mar 4, 2009
    14
    oklahoma
    My question is does the pickup floor match up with the k5 bed channels
