Well this dizzy work with a MSD Ignition box?
Discussion in 'The Garage' started by adamforsythe, Dec 30, 2006.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Why wouldn't it? Call up the MSD people and ask. :)
  3. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    What MSD box? Anyway the answer would be yes. It will not be a direct plug in like some of the MSD distributer, but will work just like the stock distributer.
  4. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    I'm running an MSD 8365 GM Pro-Billet H.E.I. unit in my 383 stroker. I spoke to Mr. Janke, the builder, about using an MSD Ignition Box, #6, Off-Road version. His response to me is that it really wouldn't give any more HP or advantage. It's not needed.
    I'm not really up on what the system does, and I didn't get into it, but I have to think that a man of this reputation who has built every type of motor from Pro Street/Racing Circuits to DD, knows a little somethin'.
    I wonder what???
    Manny
  5. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Not much more power, but does give you a hotter spark and the option of a rev limiter. I use the 6t box mainly for the soft touch rev limiter. I have bumped the limiter many many times in the mud, that alone makes it worth the money to me.
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    MSD stands for Multiple Spark Discharge. You can hook any distributor to an MSD box. It doesn't really do anything noticeable for you but it does help.
  7. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Really depends on the box. Differant boxes support differant systems. But for a stock type ignition, yes the 6 series boxes will work on almost all systems.
  8. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    It's this box: http://store.summitracing.com/partdetail.asp?part=MSD-8500&FROM=MG
    Brand: MSD Ignition
    Product Line: MSD Super HEI Kits
    Circuitry: Analog
    Rev Limiter: Yes
    Ignition Box Output: Capacitive discharge
    CD Voltage Output to Coil: 460-480 V
    Minimum Operating Voltage: 12 V
    Maximum Operating Voltage: 18 V
    Current Draw: 5 amps at 5,000 rpm
    Spark Output (millijoules): 105-115 Millijoules
    Length (in): 8.000 in.
    Height (in): 2.250 in.
    Width (in): 4.000 in.
    Ignition Box Color: Red
    Coil Included: Yes
    Coil Style: Canister
    Coil Internal Construction: Oil-filled
    Maximum Voltage: 45,000 V
    Mounting Bracket Included: Yes
    Coil Wire Included: Yes
    Coil Shape: Round
    Coil Color: Red
    CARB EO Number: D-40-26
    Quantity: Sold as a kit.
  9. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    That will work fine with that ignition as long as your not running a race only coil.
  10. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    what is a race only coil? I'm just running the basic "stock "coil
  11. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    That will be fine. Just make it worth your while and get the 6al. This is an example of a race only coil, will also give you a little infor on what the differant boxes are and what they do differant from one another.
    http://www.msdignition.com/coil_blaster_8_8201.htm
  12. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Does the 6al have a Rev Limiter? I want a Rev Limiter.
    Later
  13. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Yep. The 6a does not the 6aL L stands for limiter. You put differant chips in it to set the limiter rpm.
  14. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    sweet I will take a look see.
    Thganks
    ADam
  15. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    just get the pro billit distributer so you don't need that hei coil adapter. the box plugs strait into the pro billit and you use the blaster 2 coil like normal.
