Well Zero Compression in 4 and 5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cmoe, Apr 6, 2001.
  1. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    2 cylenders are dead
    C'moe
    <font color=black>the blazer is "Back in Black"
  2. bigerik
    bigerik 1/2 ton status
    Feb 24, 2001
    184
    Sonoma County, CA
    That sounds expensive, I'm sorry.
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    GAME OVER [​IMG] Sorry to hear that... Blown cylinder head? Time to Upgrade [​IMG]!
    1987 Chevy K5 Blazer- 350 TBI
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Unless he has a straight 6, it would have to be two bad cylinder heads. And unless some thing really bad happened (ie overheated the truck really bad), thats kind of unusual.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,092
    492
    Grand Rapids area
    Stuck valves then?
    <font color=green>"MAN THOUGHT HURT BUT SLIGHTLY DEAD" --Providence (R.I.) Journal</font color=green>
  6. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    yeah I kinda missed the s key there... I'd check to see what the valves are doing myself... these trucks quite frequently round off the cam lobes... also like was stated stuck valves... maybe time for the new cam, lifters, and some Vortech heads [​IMG].
  7. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    Don't forget a new intake to match those Vortec heads.
    Pete
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    dont think of this as a bad thing think of it as an upgrade thing lol
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Wow! So you have one dead cylinder on each side of the engine? That's ugly... [​IMG] Let us know what the results of the autopsy reveal!
  10. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    But of course [​IMG]... thinking I'm going to go w/ new TBI to vortech intake... Gotta talk to TPIS and see how much they can modify my chip and what cam... probably will step up to a turbo city bored out TBI unit as well.
  11. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    0 compression? That is almost impossible. I had two wrist pins come out of a F##d in a boom truck and with 1/8 inch deep grooves in those two cylinder wall I still had 35 and 40 psi of compression with those big grooves. So Stuck valves might make sense, but even if the rings were missing you would get some kind of compression.
    I thought I was wrong once,
    but I was mistaken
  12. dyeager535
    26,982
    191
    Let us know what it turns out to be!
    If I'm thinking correctly, the cam being flat really shouldn't be the problem. Flat cam=no valve lift=high compression, right? Although with two opposing cylinders having problems, the only thing tying them together is the crank and cam, so that would be king of odd.
    Stuck/bent valves could do it, a motor I have ingested a pipe plug (don't ask) and it rattled around until it caught the intake valve just right, and bent it. 0 compression afterwards. Hole in piston or really bad rings should result in billowing smoke from the tailpipe. At least a 2 or 4 valve job should be pretty cheap...or end up being a slightly more expensive and more powerful motor : )
    Easy enough to pull the valve covers and see if anything is wrong up top too.
    Dorian
