were to hook this wire up for tach?
Discussion in 'The Garage' started by bryguy00b, May 10, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i got the red black green and white wires for my tach. i know were they all go...but were should i plug the light one in..(white)..its suppost to go to the dummer switch or something like a dash light, does any one know what wire i should splice it to or some place in the fuse block that would work? thanx
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I hooked mine in with the fuse for the dash lights. Now if i dim the dash lights, the tach light dims with it.
  3. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    I wired mine into the fuse block where it says headlights/instrument panel if I remember correctly.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Mine tach is mounted down by my transfer case shifter, so this probably won't help any. But I just hooked that wire into the wire coming from the dash to the light in the tcase shifter so you can see what position the tcase is in. I also have my trans temp gauge mounted there too so they are both hooked up to the same line. When the lights are dimmed the tach dims too.
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    theres a light there? i didnt know that! ill have to pop the shifter cover and look..guess mine dont work..also noticed my 4x4 indicater light in the dash dont work wear shoud i look for that? thanx guys!
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    There is on my 85 with 208.
  7. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    welo i have an 86 with 208 so..
