Wet Floor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zcarczar, Dec 29, 2002.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    My floor is getting wet behind the front seats right in the corners before the tub rises up to the rear seat. The thing that gets me is that there is no visible signs of leaks any where. Any body got any ideas?
  2. tRustyK5
    Jul 23, 2000
    36,164
    1,360
    E-town baby!
    Common area for rust...that area gets the road spray from the rear tires./forums/images/graemlins/eek.gif
    Rene
  3. zcarczar
    Feb 10, 2002
    2,495
    The thing is my truck hasnt moved since friday and it rained last night. So it isnt road spray, at least i dont think it is. /forums/images/graemlins/1zhelp.gif
  4. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    check for cracks or any rot in the floor..if you have never pulled up your carpet up befor...do it and see what you flooor really looks like...allthough out there i doubt you would have to much to worry about...it might be a leak in the weather stripping wear the cap meets the cab or the side windows..doors? just some ideas..
  5. mattyblazer
    mattyblazer 1/2 ton status
    Sep 22, 2002
    202
    Long Island, NY
    Hey zcarczar
    That is a wild picture under your name, real "Dukes of Hazzard" sh!t
    It catches my eye every time you post, wheres the pic from?
    -Matt
  6. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    tear all your carpet out, Caulk where the leak is and put roll in liner in there, or if you got the cash have it Line-X'ed
  7. zcarczar
    Feb 10, 2002
    2,495
    Alright let me clarify some stuff, Carpet is out and has been out since christmas day. I have no freaking idea where the water is coming from because both the drivers side and passengers side of the floor is getting wet. I can get pictures of were it is getting wet if it might help anyone diagnose my problem. And luckily I dont have any rust yet, thank god for galvanized floors and California deserts.
    I got the pic from a video my friend shot of me jumping my blazer. The video is on my site, just follow the link below.
  8. Dale fan
    Dale fan 1/2 ton status
    Dec 5, 2002
    167
    Arkansas
    It sounds like it may be the roof or door seals although both door seals at once would be kind of odd. Since you've already got the carpet up, dry it out the best you can and break out the water hose. Start out low and work your way toward the top seal going slow. I'd start aroud the doors and then go to the roof. Watch for it running in and pooling in the floor. Hopefully you will find it.
  9. tRustyK5
    Jul 23, 2000
    36,164
    1,360
    E-town baby!
    Good advice there...
    Rene
  10. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    pic1
    pic2
    pic3
    Check the floor for rust, if its not that maybe a top seal? are the panels or behind the panels on the sides wet?
    I would bet its the floor though. Pull the carpet up and start poking around with a screwdriver! /forums/images/graemlins/smirk.gif
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    If I would have kept reading I would know you already checked the floors and the carpet was out. I would say its a door seal, or after a jump like that you might have jarred the top loose a little. Try tightening your bolts across the top and make sure your doors are closing all the way. /forums/images/graemlins/thumb.gif
    Good luck!
  12. CCRider
    CCRider 1/2 ton status
    Jul 8, 2001
    314
    Charlotte North Carolina
    Hey man I went through this before , It's probably not the seals for the top , the Door seals , it's not from jumping it, it's not a rotted out floor, it's the damn sliders!!!!! They leak if there's a heavy rain , slow misty type rain is no problem . I think there's a drain in the bottom of the aluminum frame for the sliders , and if it get's plugged up with debris , or it can't drain fast enough , it pools up in there , inside and outside the window , and will drip pretty steady !! Look @ your chrome piece that holds your top down on the inside rail , I'll bet there is evidence of water dripping/running down it . It in turn runs down onto the carpet , and the carpet holds the moisture longer than the window or the rail I mentioned ,as it evaporates from there right away !!! Had me stumped for the longest time!!!!!Good luck man! Don't really have a solution , other than getting rid of the sliders , just been dealin' with it!!! ...........................CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  13. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    The top is leaking.
  14. Doug M
    Doug M Registered Member
    Nov 8, 2002
    39
    Houston
    Agree with leaking top. My floor gets wet there after hard rain, don't have sliders.
  15. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    hit the nail on the head!
    Mine was doing this- couldn't figure it out for the life of me...till I removed the top- found the weatherstrip wasn't what i was suppose to be, replaced the weatherstrip- double checked the top for "cracks"...dry now.
    Also- the trim where the roof sits is also a culprit...runs along between the cab and cap and drips in.
    Brandy
  16. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    mine does the same thing. it leaks on the seal on the top and rolls down the rails, behind the side boards and onto the floor right behind the front seats.
  17. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Here's another vote for the top leaking. Possibly running down the sides and down behind the seats.
    John
  18. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    geez now if any one had botherd to read up farther and see that i had just said that it could have something to do with the seals.. /forums/images/graemlins/rolleyes.gif
  19. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Yes, you did......
  20. tRustyK5
    Jul 23, 2000
    36,164
    1,360
    E-town baby!
    It might be the seals... /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Rene
