What 10b crossover kits are out there?
Discussion in 'The Garage' started by dremu, Sep 3, 2005.
  1. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    I know about the ORD kit, and have my flat-top D44 knuckles waiting =))
    There's also the ORU kit, which requires insane lift 'cuz the draglink is straight. :screwy:
    Any others? I'm just contemplating options for this winter's projects :haha:
    -- A
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
  3. dremu
    Feb 27, 2000
    15,954
    445
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Correct, the only difference between a 10b and D44 crossover kit (besides having to use D44 flat tops) is the axle name. One kit fits both axles.:D
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am running Sky Manufacturing's D44 tall steering arm. It is a quality piece of hardware. I would not hesitate to run there stuff again.
    Harley
  6. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    I agree, I had the sky man. Tall arm and that thing was beef. It was a good price for the arm too. I would be running it but i recently traded it with some d44 flatops for an almost complete d60. I would recomend checking out sky's stuff. Great service too.
    Also WFO i think has some dana 44 stuff. Might wanna check them out too.
  7. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    [hijack]
    I plan to use Sky's tall arm for my D44 crossover also. I remember someone having a problem with sheared studs, which I think turned out to be a (lack of) torque issue. Are these arms safe for street use?
    [/hijack]
    :confused:
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Yes it was a problem but only became heavily evident when using a spacer. The new ones are better and safe for street use. Harley (Hossbaby50) had a massive problem with the studs, bolts, grade 5 & 8 also F911 (aerospace equivilent to a "grade 9" if there was one). Couldn't keep them from shearing/streatchin' to save our tail. He got the newer arm that is a full billet piece and no more problems. I also know of 2 other rigs with the same problem. I think we changed 15+ steering arm studs/bolts out last year on the trail due to this.
    It was a leverage issue that I found after calculating the shear, and torque load on the stud. The spacer allowed more torsional movement due to a two series interface (spacer on knuckle & arm on spacer). The small amount of movement that will always be there obviously doubled due to the number of interfaces. This casued the fastener to reach its fatigue point faster and was constantly seeing a greater amount of torsion force against its natural axis (the stud was twisting/bending against the shank, not along it).
    Basic idea -> bend: weaken, bend: weaken, bend: weaken, bend: break.
    (Sorry for the long explanation, back in school means back to more engineering)
  9. divorced
    Jul 20, 2004
    5,115
    That is a good explanation, and thanks for the info.
  10. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I got everything from WFO concepts because, depending on availability, he can sell flat-top knuckles milled, drilled, tapped & ready to go.
    Mike
  11. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    What Matt said. The spacer was my main problem with breaking studs. I broke the steering studs from Sky on my 2nd run out. Then I replaced them with Grade 9 F911 bolts. I ran those for awhile on some hard runs. I never broke them but I did end up stretching the bolts and the steering arm got a little loose.
    I sold my standard height steering arm to a friend of mine and I bought Sky's new tall arm. I run there new tall arm with 2.75" long Grade 9 bolts. I have had no problems since I switched over. The bolts are still tight and have not stretched or broken.
    People say bolts are not the correct way to do it but they have been a better solution to my problem. The key to keeping the steering arm in place is the clean mating surfaces (no oil or paint), quality fasteners, and HEAVY torque on the bolts or studs.
    My bolt are torqued to 220lb-ft. currently.
    Harley
  12. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I had all the sky stuff (still have the draglink/pitman arm) but I have to say the tall arm was NICE.
    With out a doubt go with Sky. You wont find stuff cheaper with that good of quality anywhere.
