What a mess..
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, May 7, 2001.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Last night while driving to a nearby Target one of the power steering hoses came loose,and ended up touching one of the moving belts causing a rip in the hose. There was steering fluid everywhere. My question is what can I do to stop this from happening again??
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  2. freeforever
    freeforever 1/2 ton status
    Feb 21, 2001
    305
    Missoula, MT
    Get some good clamp downs and get some braided hoses...good ones tho...my friend has the braided ones in his ford and a hose came looses and hit the fan, it just skiped off and landed next to the fan shroud...just left a dent ! well hope that helps some :)
    "You can talk the talk...but can you walk the walk?"
  3. dyeager535
    26,982
    191
    Your truck (80's right?) should have a hold down for both the power steering lines to the frame.
    Dorian
  4. UseYourBlinker
    Jun 7, 2000
    11,117
    Yes it does have a hold down. The problem was the line closest to the fan,the fitting backed out a little bit and moved the line in the path of moving fan belts.. The hold down was tight. Anyways the new line cost me about $26.00. I want to keep the lines clear of the fan belts in the future. Right now they are zip tied together...So far it has worked [​IMG]
