What air pressure do ya run front, rear?
Discussion in 'The Garage' started by dontoe, Mar 31, 2005.
  1. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    What pressure do ya run on yer DD?
    Front tires/rear tires?
    What type vehicle?
    And I suppose the size/type tire would matter!
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    33 inch radial Sport Kings . I have run a slow as 25 psi , as high as 35 psi .
    I have found the best balance between ride and handling is 28 psi . Perfect tire wear too , rotate often for the rear locker though so no one tire gets too much wear .
    I wish I had a tire machine , damn tire shop always airs them up too much . like 40 psi , and then I have to pull over and air em down :k5: :k5:
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Normally I run 28 rear and 32 front. Have for years with 33'' BFG's. Trying that with the35 BFG's seems kinda bouncy!
  4. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    its not a DD, but when i do drive it on the street it is, 15-14 in the front, and 13-14 in the rear. 39.5 boggers in the rear, and TSL's in the front.
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    i run 30 in the front 26 in rear w/ 35x14.5 SSR's......actually I havent checked em in a while.......need to go check em when it quits raining.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    39.5in iroks i run 23 front and rear on the street 8-10 on the trail and 4-6 in the sand :D
  7. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    6800 lb K10 on 44" boggers (15x12 wheels): 18 front 15 rear for highway driving, 15 front 12 rear for general around town and off roading locally, 12 front and 8-10 rear for the bigtime trails like Tellico
    '89 Dodge Dakota 4x4 with 325/60R15 BFG A/T on 15x8.5 wheels: 32 front, 28 rear
    97 Dodge Ram 1500 2wd with 275/70R16 Dunlop Radial Rover A/T on 16x6 wheels: 35 front, 32 rear.
    98 GMC Safari with 235/70R15 Tech 5000's on 15x6 wheels: 35psi all around.
  8. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    40" hawgs... max rated @ 30psi... I run 24psi all round...
  9. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    36" tsl radial swampers. I think there at 35 or 40 psi. so far after an year are so they wearing pretty good.
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    37" mtr's on 15x8
    25 psi
  11. suthrnchvyguy89
    suthrnchvyguy89 Registered Member
    Oct 10, 2004
    51
    charleston, sc
    33x12.50 ssr's i think the max is 33psi, i usually run about 30psi
  12. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    31" BFG muds on my '91 DD are at recommended 30f 35r.
    My '78 on 33"s has 20 f&r and it's smoothed out the stiffer suspension a bit but does kind of wollow and bounce a bit!
