What air pressure should I run in my 38.5x16 TSL's????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fad2blk99, Dec 18, 2003.
  1. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    What air pressure should I run in my 38.5x16 TSL\'s????
    I think I'm running about 19 psi now.... what do you guys run or recomend running for highway driving?
    The tires are TSL (Bias ply) 38.5x16 on 16.5x12 aluminium wheels.
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Re: What air pressure should I run in my 38.5x16 TSL\'s????
    what is the maximum tire pressure? I would run around 5psi below max with your 16.5x12's. I have 35x16 boggers on 16.5x14's and maximum tire pressure is 30 for them and I run right at about 25to 30 psi on and off road.
    Tire pressure depends a lot on your tread and rim width, we are about the same because my boggers are wider than the TSL's but with 14's it's about the same. At 19psi on the highway I am afraid they would run a little hot.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i run 23psi in all 4 of mine for the last 2 years and have almost 40,000 on them and still have about 30% tread left /forums/images/graemlins/thumb.gif
  4. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Here is a way to determine proper inflation of your tires.
    Get the manufactures tread width information. (in your case it is 13" for standard 38.5*16*xx TSL's)
    Drive through a puddle of water at xx PSI and measure the tread with left from the water tracks.
    If it is wider than the spec'd tread width inflate the tire, if it is less deflate. This is the best way I know of to determine the correct PSI for the tires your are running. Of coarse if you can't get there with-in the tires MAX PSI you truck is just to damn heavy for the tire. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/grin.gif
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    An easy way to do it would be to just park on asphalt and get down on the ground and look at your footprint and make sure you are making contact from outside lug to outside lug.
    I have a flat footprint and 27psi, sometimes it's nice having wide rims. /forums/images/graemlins/smile.gif
  6. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Cool... I'll give those suggestions a try... thanks!
  7. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    For yet another way Read this
    It works. /forums/images/graemlins/thumb.gif
