What All Do i need
Discussion in 'The Garage' started by sd17sd, Jul 15, 2005.
  1. sd17sd
    sd17sd Registered Member
    Feb 3, 2005
    15
    Jackson,TN
    :D What all do i need if im gonna put a Suspension lift on my 1986 K5......im goona use the shackle flip from ORD and also gonna use the front suspension lift with new springs and everything....so besides that what all do i need
    :D
  2. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Cutting torch or Big air chisel to remove the rivets holding the stock shackle mounts on, floor jack, jack stands, various hand tools, cut-off tool for the front u-bolts ( you can spin the nuts off but a cutting wheel is a lot faster).
    There are pics on my page of the flip kit installed, don't forget a 12 pack of suds.
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    I hope the kit comes with raised steering arm and you got some extended brake lines. Impact wrench can make life alot easier. I used grinder on rivets. I also got alot of use out of my sawz-all and hammer. :wink1:
  4. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    dont forget shocks!!
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Bfh. :D
  6. mr_beer
    mr_beer 1/2 ton status
    Sep 10, 2004
    325
    Mt. hermon LA
    Combine the BFH and the 12 pack of suds and you will get it done in no time. :wink1:
  7. wicked87_k5
    wicked87_k5 1/2 ton status
    Aug 9, 2004
    235
    Little Falls,NJ... North
  8. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    A 4" lift does require extended brake lines..at least mine didn't
  9. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Well it may not but new steel braided lines are nice to have. Ive always used 'em.
