What all has to come off...UPDATE AT BOTTOM
Discussion in 'The Garage' started by 84gmcjimmy, Oct 16, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    In these pictures, what all has to come off the firewall, in order to take the body off? So much to do, so less time.
    Sorry if this is a dumb question, but I seriously need some help from you guys!
    How do all these come out? Some look like they just pop off, some look like they have a special sealent around them /forums/images/graemlins/dunno.gif
    How do I get those plugs out? Are they bolted to the firewall with that bolt in the center? I tried just pulling on the plugs, but they didn't move...
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: What all has to come off...
    for the body to come off you need to get the brake set up off or just pull the 2 lines off the master cylinder. then on the wiring just take that bolt out and the two halves will seperate.
  3. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    unscrew that bolt in the middle of the harness, then wiggle the harness till it comes out .
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Dissconect your break lines, fuel line, and any linkages for throttle, transmission, transfer case, ... ect. Jack body up slowly while checking for wires. Trust me, you'll always find wires that need dissconected.
  5. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    park brake cable too! /forums/images/graemlins/thinking.gif /forums/images/graemlins/waytogo.gif
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Yikes. I better start a list /forums/images/graemlins/doah.gif
  7. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    steering shaft between the box and column. also if an auto, the shift linkage needs to go also
  8. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    column is already out. I edited my reply after relooking at the picture,LOL
  9. GMCLegacy
    Jan 24, 2002
    620
    Grand Haven, MI
    i guess i looked too quickly too,
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    How about another dumb question. I was going to take the 2 spiraling lines off the master cylinder a few days ago, but the way it looked, if I took the lines off, all the fluid from the resivoir would come out? Or no?
  11. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    speedo cable!
  12. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    well I went out there an hour ago and started workiong on it again...
    I got some of the wires off the firewall. The one I took a picture with was so easy I could have cried. I unbolted the bolt, and wiggled it abit, and the whole thing came off. I never knew it was one bit connecter /forums/images/graemlins/woot.gif
    Then I took the 2 spiralling lines off the master cylinder, hardly any fluid came out, just a few table spoons.
    Then I took out the 2 bolts holding the ball thing that is to the right of all the wires on the firewall (I dont know the name of it, anyone know? It was empty when I unbolted it /forums/images/graemlins/thinking.gif )
    Then I took the front driveshaft off which was a bit of a pain... then I got the x-case shifter linkage off, i hate cotter pins /forums/images/graemlins/mad.gif
    Now I have a question, on my front driveshaft, the u-joint where the axle is, I touched one of the end caps, and it fell off? Is that supposed to happen? Only 1 needle bearing fell out when the u-joint cap hit the ground.
  13. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    That would be called a vacuum canister /forums/images/graemlins/thumb.gif
    Yes, the end caps of a u-joint just slide on and off like that(unless they are bolted on and they slide off - that is not good).
  14. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay thanks.
    Another dumb question, what does the vacuum canister do?
  15. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    another question, where do the fuel lines come off?
    What is the easiest way to get the throttle cable off?At the carb, or in the tub where the foot pedal is?
  16. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Dont forget the gas tank filler neck and vent hoses(I have! /forums/images/graemlins/blush.gif).The vacuum ball dewhickey stores some vacuum,like a reserve tank. /forums/images/graemlins/crazy.gif
  17. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    ah I forgot about the gas tank neck. yikes. and breather /forums/images/graemlins/doah.gif
  18. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Fule lines are easiest down by the fuel pump. Lower front passenger side.
    Throttle cable is much easier at the carb. Should be a weird little clip, and then the cable will pretty much fall off.
    Filler neck and breather is just a hose clamp.
    Anyone mentioned the steering shaft? You can remove the bolts through the rag joint. Also need to undo the power steering lines.
    Rene
  19. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Rene
    OKay thanks, I saw the weird clip of the throttle cable by the carb, I will take that off.
    Filler neck and breather are just a hoseclamp? sounds easy enough.
    I will look for the fuel lines after the snow quiets down.
  20. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Man, what a mess. When I pulled my body there was a few wires, brakes and steering! Have fun!
