What am I not thinking of?
Discussion in 'The Garage' started by BIG*RED, May 23, 2005.
  1. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    ok, i've got something going on with the front end on my k-5, and i haven't found anything wrong. perhaps i'm missing something?
    its a 82 with the d44 front end, ord swaybar disconnects, 4 inch lift,35 inch tires..
    when driving over curbs, speed bumps, large pot holes, i get what sounds to me as a loud metal on metal clank,thud, thump (pick one). feels as if the front end is falling off.
    i have checked my ball joints, my power steering gear box (sector shaft is slightly worn) no cracks in the frame, tie rod and ends are new, hubs new, drag link is worn..but i don't think thats what is making the noise, leaf springs have newer poly bushings, all bolts are tight, u bolts ae tight. shackle bolts tight, all bushings in execellent shape. so is there something that i'm missing that i should check? the noise comes from the drivers side.
    its got to be something that i'm not thinking of right now....
    thanks in advance for the help
  2. dyeager535
    26,982
    191
    I know you said all bolts are tight, but are the shocks tight at both ends, and the proper spacer is in place at the top? (Just noticed on my dads that Big O tires installed his front shocks without the upper spaces, they rub on the frame. :mad: )
    Only things loose on my truck so far were the shocks loosening up, and the tranny crossmember bolts loosening up.
  3. texas78k5
    texas78k5 Registered Member
    Apr 24, 2005
    26
    Kerens, TX
    My jack had worked itself loose under the hood on passenger fender....had me puzzled for a while!
  4. BIG*RED
    Mar 14, 2003
    1,094
    nope, couldn't be that simple for me..lol 'cause the only jack i have is the 3.5 ton floor jack in back..
  5. BIG*RED
    Mar 14, 2003
    1,094
  6. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    I also have that same mystery noise in mine. It is a stock 83 though. It was realy bad till I replaced the tire rod ends.
  7. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    check crossmembr bolts''the one the motor mounts to'' mine worked free from flexing a lot.
  8. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Ah, beware of that thought! Ever looked for something for hours only to find it the next day right in front of you? Is it a heavy sound or a light one? Do you see any shiny metal from metal to metal contact? Loose a socket somewhere?
  9. BIG*RED
    Mar 14, 2003
    1,094
    yeah its a heavy sound, i haven't found any shiny metal areas, sounds and feels almost like the front axle is about to fall off.
  10. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    Maybe it is then.
  11. BIG*RED
    Mar 14, 2003
    1,094
    aw come on now, don't say that..lol...thats not what i wanted to hear
  12. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    how are the inner fenders?
    i know on my 86 the were just floping around in the fender making a bunch of noise when i hit bumps, then one day one fell off and the noise was gone
  13. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    This will without a doubt be the dumbest suggestion, but, lug nuts all tight? The ones most taken for granted are the ones most overlooked.
  14. BIG*RED
    Mar 14, 2003
    1,094
  15. BIG*RED
    Mar 14, 2003
    1,094
    yep lugs are good, check them periodiocally...
  16. emoo99
    emoo99 1/2 ton status
    Jan 16, 2003
    494
    Washington
    u bolts?
  17. texas78k5
    Apr 24, 2005
    26
    Kerens, TX
    Bumper?
  18. Boondocks
    Boondocks 1/2 ton status
    May 10, 2005
    129
    Massachusetts
    Have you checked for play in the spindle bearings?
  19. BIG*RED
    Mar 14, 2003
    1,094
    ubolts are good
  20. BIG*RED
    Mar 14, 2003
    1,094
    bumper and spindle bolts are also good...
