What are 'cutting brakes' ?
Discussion in 'The Garage' started by muddin4fun, Jun 4, 2002.
  1. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    What are \'cutting brakes\' ?
  2. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    Re: What are \'cutting brakes\' ?
    Lara, cutting brakes are separate brakes on each rear wheel, that can be actuated separate from each other to help steer the vehicle. They are very common on dune buggies /forums/images/icons/smile.gif.
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Sandrails use them (as does SW from ORD) to separately actuate the rear brakes, left or right, individually to allow you to lock up the inside tire to facilitate an extremely tight turn............in a sandrail at speed it is way cool........./forums/images/icons/cool.gif
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    They won't work if you have a locker in the rear unless you can switch to front wheel drive only. Then they can make it realy "turn on a dime". /forums/images/icons/smile.gif
  5. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    K...sorta like tractor brakes....mkay /forums/images/icons/smile.gif
  6. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Yep if you've driven a tractor then you know what they can do. They won't work with a locker unless you can discontect that axle.
  7. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Can't wait till they make the arb for a 14ff
    *pfft*
    /forums/images/icons/laugh.gif
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Or you can do a twin-stick 205. That's on my "to do" list somewhere around 2010 at this rate. /forums/images/icons/laugh.gif
  9. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Yep that's on my list too. Maybe this winter or next year. I want to get a new/ extra range rail and have it ground for twin sticking. Then when I'm ready I'll put it in.
