What are my 14bsf traction device options
Discussion in 'The Garage' started by 88K5Jimmy, Dec 14, 2005.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    I can't really find very many options for my 14bsf and with the recent talk about 14bsf and the last trail run I went on, I figured I would investigate it. This I do know:
    -Not welding it because it's a DD
    -Detroits are $648 per 4wheelparts ad
    -Detroit Trutracs are $520 per 4wheelparts ad and what exactly is that, more like a limited slip?
    -ARB's are just to outrageously priced and I don't want one
    -Not going to swap in a Gov-bomb
    -No I'm not going to put in a 14bff because I don't need it so don't even mention that!!!
    Just seems everything is really expensive for the 14bsf.
  2. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    Yep, very expensive. I got the Detroit. There's just not much demand for them and it is a full carrier replacement.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Drivetrain Specialist sell the detroit, eaton limited slip, auburn limited slip and the gov-bomb. Give them a call or visit their website they are pretty knowledgable and freindly over the phone.
    Ira
  4. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    eaton limited-slip and a gov-lock are one and the same
  5. Tuff84blaze
    Tuff84blaze 1/2 ton status
    May 12, 2000
    119
    Liberty Lake, Washington
    My Brother got one (Detroit) from Randy's Ring and Pinion last year and I remember it being somewhere around $500.
  6. sandawgk5
    Oct 28, 2003
    6,881
  7. sandawgk5
    Oct 28, 2003
    6,881
  8. sebban
    sebban Registered Member
    Jan 18, 2005
    63
    sweden
    My buddy just ordered a lockright from summit. 385$.
    PWT-1950-LR
    /Seb.
  9. hack500
    Sep 16, 2005
    523
    Templeton, Ma
  10. dyeager535
    26,979
    Eaton makes the gov-lock, they also make the flat plate clutch styles as well. Both G80 option code for GM.
    *Supposedly* Eaton is coming out with an 800# preload 14SF LS carrier, that was according to a tech at randy's ring and pinion.
    I did some research on this, http://coloradok5.com/forums/showthread.php?t=147299&highlight=14sf
    I think I'm back to the tru-trac honestly. I believe Eaton now owns this too. If Eaton comes out with the 800# version of the LS, I may go that way, but the tru-trac is about as close to a gov-lock as you can get, (in all manner, not just one way or another) without actually having a gov-lock.
  11. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    PM sent. As a dealer for Randy's R&P. I can sell you stuff cheaper than they will. I can beat those prices by a LOT.:wink1:
  12. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    So I've done more research and found the Powetrax/Lock-Right. Seems to be a drop in lunch box "locker" if you will, that disengages when going around turns, which is what I need since I still drive it on the street. Anybody have any experience with these?
    http://www.4wheelers.com/lock-right-locker-1950-c-117-p-840.html
    So far that's all I've been able to find that's not rediculously expensive and doesn't require anythign special to put it in. Thoughts?
  13. dyeager535
    26,979
    I looked at all that stuff when I was having problems with my gov-lock as well, I just couldn't justify a lockers behavior for my driving style. Just can't keep my foot off the throttle in corners. I know it would drive me crazy, except the rare times it was needed off-road.
    My choices were down to the e-locker and one of the Eaton clutch posi units with the 800lb springs, but for some reason the gov-lock quit acting up and now works like a champ again.:confused:
    You are right, prices are up there, and the e-locker is outrageously expensive comparatively, but it would be nice. Would be pretty cool to tie it into an ABS system so it didn't need your input, or you could just tie it into the 4WD light to trigger it for default operation, with a manual switch for over ride. Fun stuff, just not sure it's worth the what, $800?
  14. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    I have a Truetrac and love it.
  15. dyeager535
    26,979
    Truetrac was another option, but thats one of the modulated brake styles, not locked up solid. I like the design better than the clutch limited slips.
    I know nothing of these guys, but they are like $200 less than summit for the elocker, which brings it closer to the truetrac price at summit.
    http://www.4wheelerssupply.com/catalog/product_info.php/products_id/71416
  16. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
  17. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    My understanding is the Gov-Lock for the 14B is a pretty robust unit compared to the 10B version. I believe Randy's will take the normal Eaton LS and rebuild it with the #800lb clutch pack. I thought about doing this to my 10B Eaton when they wear out. I have also heard the #800lb unit tends to chatter pretty bad on turns so not sure what is worse, a locker or a chattering LS.
  18. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    Did you ever consider the Eaton E-Locker. I put one in a few years back and Love it. I think it was around $500 then. It may be around $650 or so now.
    Easy install and It's either Locked or Open.
  19. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Yeah but too expensive for my needs. I actually ordered the Lock-Right from Tellico 4x4 for $358.05 shipped. I think I will be happy with that and the price wasn't bad at all.
  20. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Have a lockrite in my 14SF and couldnt be happier.. Cant beat the price nor the performance/good road manners.
