What are the major differences between oil and oiless compressors???
Discussion in 'The Lounge' started by chevyfumes, Apr 16, 2004.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    /forums/images/graemlins/deal.gifMy Brother says to get an oil, because their quieter, if thats the entire reasoning behind them then WTF, it's going in it's own little room in the shop???? /forums/images/graemlins/1zhelp.gif
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    One as oil one doesn't... Sorry, couldn't help myself... /forums/images/graemlins/yikes.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Oiless compressors have smaller displacements, so they spin the living crap out of them to get a decent CFM rating. And yes, they are deafening to be near. The difference is VERY noticeable. The oiless type are basically just an upsized version of those POS compressors that plug into a cigarette lighter. /forums/images/graemlins/eek.gif
  4. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    To the best of my knowledge (ok, setting self up for failure!!), the oilless ones use a teflon lined chamber. This allows for the piston to move without siezing up. They are normally cheaper and are considered disposable. I've heard of some people replacing the teflon insert, but I don't know for sure. The oil ones will typically last alot longer as long as you change the oil. I change mine once a year, but I only use it 8-10 hrs a month average. I bought the small vertical (26 gal I think) Husky AC & I love it. However, when I work on my trucks, I can only get 2-4 lugs loosened/tightened before the ac kicks on & I need to wait for pressure. I'm looking for a new larger one, but other priorities first.
  5. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    And this sir is what we pay $25 per year for! LOL! /forums/images/graemlins/histerical.gif
  6. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Yep, Don't you feel like you got your moneys worth.. How bye the way.. The one that is oilless.. That's the one with out oil... /forums/images/graemlins/waytogo.gif
  7. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    What difference does it make if your electrician can fry either one in 5 minutes? /forums/images/graemlins/yikes.gif /forums/images/graemlins/whistling.gif
  8. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    My 1 gallon oil less compressor for my air brush is louder then my 60 gallon oil one.
  9. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Unless it has its own insulated room, the noise is maddening. Mine does, and it is still anoying. I've had my Craftsman (5hp/25gal) for 6 years and it still works great, but if I knew then what I know now I would have spent the money on an oil type. All industrial types are oil lubed. My dad's had his normal (oil type) Craftsman (20gal/???hp) for over 30 years. The big one in his shop is much older, but its 3 phase and has a tank over 100gal. As always YMMV.
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I bought one of those back around '92 or so. After it finished filling the air tank the first time and finally shut off, I unplugged it, drained the air, and took it right back to Sears. /forums/images/graemlins/eek.gif I told them that the damn thing should come with "Hearing Protection Required" stickers! /forums/images/graemlins/angryfire.gif
    The next day I bought a Sanborn 5 HP dual piston oil-type compressor and it still works great. /forums/images/graemlins/thumb.gif
  11. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    bought one of those back around '92 or so. After it finished filling the air tank the first time and finally shut off, I unplugged it, drained the air, and took it right back to Sears. I told them that the damn thing should come with "Hearing Protection Required" stickers!
    I wish I would've had enough sense to do that when I got mine. I have a Craftsman 5.5hp, 33 gal and that damn thing is LOUD! Good thing it's about 75ft away from the truck, or else I'd be deaf...
  12. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Me too, like I said if I knew then... If it wasn't in a seperate room I probably would have.
  13. chevyfumes
    Feb 24, 2000
    38,584
    266
    So something like this one???? craftsman... /forums/images/graemlins/dunno.gif /forums/images/graemlins/thinking.gif
  14. chevyfumes
    Feb 24, 2000
    38,584
    266
    or this??? cambell... /forums/images/graemlins/deal.gif
  15. chevyfumes
    Feb 24, 2000
    38,584
    266
