What are the pinion shaft return spring specs?
Discussion in 'The Garage' started by BigBurban350, Jul 9, 2003.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Can you help me out, I need the specifications.
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Huh? /forums/images/graemlins/confused.gif
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Are you talking about the pre-load springs for the side ( axle ) gears in a L/S diff. that go around the center pin ( could be called a pinion for the small pinion spider gears )??? If so what kind of diff. are you refering to ?
    Tom
