what are the ratio splits for 10 bolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BIGRIG, Dec 9, 2002.
  1. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    Is it true that you can run the same carrier for 2.73+, or is there something that you have to change with the gears?
    Thanx
    Chris /forums/images/graemlins/usaflag.gif
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    im pretty sure its true
  3. dyeager535
    26,980
    old email I saved
    "The 8.5" 10-bolt has one carrier break. All gear ratios numerically lower
    than 2.73 use a 2-series carrier. 2.73 and numerically higher use a
    3-series carrier. If you have a 2-series carrier, you can use 3-series
    gears on it with the addition of a spacer. "
  4. BIGRIG
    Feb 29, 2000
    488
    Independence, MO
    thanks! just what I needed to know!
    Chris
  5. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    As long as your truck didn't come w/ 2.43s you don't need to change. The next step up was the 2.73, which as stated above, goes all the way up.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    2.43 was an available ratio in the 8.5" in these ? in the trucks ?
    only ones i knew of in truck 8.5" were 2.73, 3.08, 3.42, 3.73
    now cars is another story, caddies used 2.21 and theres an oldsmobile ratio one step higher ratio than that even ! 2.0-something
  7. BIGRIG
    Feb 29, 2000
    488
    Independence, MO
    Yep! and guess who got screwed with 2.73's... /forums/images/graemlins/thumb.gif this guy!!
    Not to great with 35's but I do get 17mpg roughly with a t350 and a stroker motor /forums/images/graemlins/shocked.gif
    Chris
  8. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I'd have to look it up again to find out for sure, but that is what I remember reading. I don't remember what years it used or if was only a 2WD thing but they are out there. The highest I have had in any truck I have owned were 2.73s
