What are these metal pieces in my oil pan?
Discussion in 'The Garage' started by dremu, Feb 5, 2007.
  1. dremu
    Feb 27, 2000
    15,952
    444
    East of San Francisco
    Though I do not claim to be a motor guru, I believe it is safe to say that these should not be there. ;) :doah:
    So, any ideas on what they are, 'fore I tear the whole freakin' thing down? Spark plug provided for size reference. One big chunk, and a bunch of little ones that, while curved, are also tapered in on the end like the tines of a fork.
    I presume they were a sleeve or bearing or something in a past life, before whatever bad thing happened, unless somebody stuck a fork into the engine :eek1:
    Any pointers on what to go looking for appreciated.
    http://www.slosh.com/ck5/uhoh.jpg
    -- A
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Hey man you found my fork, I've been looking for it.
  3. dremu
    Feb 27, 2000
    15,952
    444
    You have a small mouth. :)
    -- A
  4. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    yeah, i think you have a connecting rod getting up close and personal with your crank. dead bearing. i'd use the truck to hold down the driveway until i rebuilt the bottom end or just swapped the engine. my 2 cents.
  5. dyeager535
    26,975
    The one large piece looks a little like part of a rod bearing, but still seems small. They are magnetic, and not piston pieces?
    I wish I could help you more, can't think of anything else off the top of my head that looks like that in an engine.
    I got a couple of weird pieces in my oil filter that I cut off too...very fine thread, somewhat metallic, brown, somewhat looks similar to hardened JB weld. Nothing in my engine would look like that either lol.
  6. dremu
    Feb 27, 2000
    15,952
    444
    They are ferrous, yes. Are pistons aluminum, or magnetically dead or something?
    :doah: Karnak The Invincible sees a motor tear down in my future.
    -- A
  7. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    LINK no work ???
  8. dremu
    Feb 27, 2000
    15,952
    444
    Works for me and others. OTOH, see attached.
    -- A
  9. kgillyk5
    kgillyk5 1/2 ton status
    May 29, 2003
    1,830
    Fultonville, NY USA
    Don't worry, that's not an oil pan...it's a bed pan,...those parts wont hurt your bed pan at all.
  10. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,991
    130
    Pistons are aluminum, bearings are steel and brass I think.
    Those pieces look like a very dead bearing to me.
  11. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    i would have to say those are definately a bearing, just saw that a few months ago in my friends 350.
    did you hear the engine making any noises at all?
  12. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Looks like a bearing to me.
    -Harrison
  13. kp texan
    kp texan 1/2 ton status
    Sep 8, 2003
    211
    Corpus Christi, TX
    Bearing material would be non-ferrous though correct? Aren't they typically made of babbit?
    -Wes
  14. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    all the bearings ive ever seen are aluminum, copper and babbit.
  15. superwrench
    superwrench Registered Member
    Feb 2, 2007
    20
    Little Rock, IA.
    Was the motor knocking? Useually bearing material that comes out is rough and burnt. Motor should have a good knocking noise also. By the shape of them ,it looks like it could almost be valve springs.
  16. dremu
    Feb 27, 2000
    15,952
    444
    I didn't hear this one run 'fore I got it ... long story, but it was allegedly good.
    Valve springs, interesting. ::shrug:: I also found a visibly bent pushrod, so I've got my work cut out for me :)
    -- A
  17. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    I was thinking valve spring dampers - the coils made of flat material that they put inside the main spring. If it is a bearing I would guess that it may be a cam bearing walking out and getting shredded, or the thrust bearing is getting torn up. In any case it is bad and you need to take a peek inside :eek1:
  18. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The tapered pieces are definately inner damper springs.
  19. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    the big piece looks like a bearing, my bearings where steel liner with cooper and babit, when I torched my motor and had 2 bearing showing only steel liners.
  20. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    I'm in class right now and I showed my teacher the picture...he said the same exact thing by just looking at the pic...he said that he thinks its a cam bearing walking out and getting chewed up...also look at how uniform the pieces are...
