What are these springs?
Discussion in 'The Garage' started by mountainexplorer, Sep 9, 2004.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    How much lift do you think these springs are? They are under a 1980 Chevy minus motor.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    By the number of leafs, I'd say either 6" or 8", but more like 6"
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    they look alot like my bds springs
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    hmm no engine?!?!?! /forums/images/graemlins/thinking.gif 6" or 8" Skyjackers
  5. mountainexplorer
    Nov 14, 2001
    4,903
    Ok, after looking at these pictures myself, the photos seem to skew how they really look. In person, they seem to have more arch, which is why I'm questioning.
    They are supposedly 6" Pro Comp springs. However, I have 6" springs under my Crew Cab and Suburban, and these seem to have as much arch as the 8" springs under another rig. Of course, no weight of a motor makes a difference, but the guy I got the truck from also said that the front always seemed to sit a bit higher even when a motor was in it, and with 6" rear blocks.
    It's alot like the "big Crew Cab". It had a 6" lift we were told, but always sat higher in the front. When I put an 8" lift under another rig, the front sat the same as the "big crew cab". The springs were pretty much the same.
    I have another 8" all spring lift I was going to put onto a frame. If the fronts are the same, I'll just put the 8" rear under this frame and be done.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    They look like my Pro Comp springs , even though mine are 4 inch ( red bushings and overall look give them away ) , what number is on them ? . Put some weight up there and they will come down some I'm sure . Without a motor its misleading , I am using my old stock springs ( temporary ) on the motorless project , and they went from negative arch to positive arch ( 3 inches or so ) /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I definitely agree, those are most likely 6" springs.
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    they look like my old 6" springs that are now in a buddies truck.
  9. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    They look like 6" springs to me. The drag link angle also is consitent with that of a 6" lift.
