What are these things?
Discussion in 'The Garage' started by Element, Apr 22, 2007.
  1. Element
    Element 1/2 ton status
    Mar 23, 2007
    314
    WV
    Couldn't find anything about them in the Haynes manual, and I have no clue what they are. I'm told replacing them could solve the problem with my truck cutting out whenever I put it in reverse :confused:
    (Sorry for the pic quality, phone pics):
    Some sort of positive jumper?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Terminal block.
    I doubt that it causes your truck to stall.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    cutting out when you put it in reverse? this start since you put in the new trans?
  4. Element
    Mar 23, 2007
    314
    WV
    I bought it with the TH350 in, so I'm not sure...it just cuts out 75% of the time, hot or cold, when I put it in reverse.
  5. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    the first one is a circuit breaker, it is not factory. the second one is a terminal block like readymix said
  6. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    nooo. is it only when its cold that it ucts out?
    waht are yuo idleing at? if your around 4-500ish wehn in D or N your too low bump it to around 750.
  7. Element
    Mar 23, 2007
    314
    WV
    No tach, so I'm not 100% sure, but it feels around 600rpm, and when I put it in reverse and it doesn't cut out, it feels like it drops to about 300-400rpm, really bogging down.
    Cuts out hot and cold, runs rough hot and cold. Plan on buying a code reader here directly, since the dash SES light is out and I can't do the paperclip method.
    How do I change the idle speed on a TBI?
  8. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    when you put it in gear it will drop rpms. its just waht happens...lol.
    there should be an idle adjustment screw...on the throtlte body drivers side where the throttle cable is...there should be a screw that if you tighten it will bump up the rpms.
  9. readymix
    May 30, 2004
    6,706
    26
    Nope. To adjust idle on a TBI you need to adjust minimum air.
    Look over at the third gen website for good directions.
