What are you working on this weekend!!!
Discussion in 'The Garage' started by 87GMCJimmy, Jun 28, 2002.
  1. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    For once I finally have a weekend where I don't have a bunch of other sh*t to do and can work on the truck. Gotta get it ready for Moab. List of things to get done this weekend:
    1) Weld up rear shock mounts, Upper and lower.
    2) Replace front lower shock mounts.
    3) Build new fuel lines.
    4) Mount computer/fuse box.
    5) Buy a battery.
    That should make for a great weekend! Once I have the rear shocks on I can take it to the exhaust shop and have it built. It's getting close to being on the road!
    What are you guys working on!
    Later
    Mike
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Number one on the top of my "sh!t list" for stuff to do is:
    To stay indoors, out of the heat, and be cool as much as possible!! /forums/images/icons/tongue.gif /forums/images/icons/grin.gif
    I'm also gonna stay home all weekend and lounge around and check out CK5 about every now and then. /forums/images/icons/wink.gif
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Going to Blazer-fest in Hollister...
    YYYEEEEEEEAAAAAAAHHHHHHH!!!!!!!! /forums/images/icons/grin.gif
  4. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color="blue"> Build a patio on the back of the house with patio paver blocks ! It's gonna be hot too ! I have to get it done before the new air conditioning system goes in since the outside unit will sit right there ! </font color>
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    1. Fix exhaust
    2. Find a suitcase full of 100's
    3. Spend suitcase full of 100's accordingly......
  6. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I just finished installing my 4" lift (thanx "Rockjunkies") last week, so this weekend entails;
    Installing new rear wheel brake cylinders
    Bleeding brakes
    Getting rims for my "new to me" 33's and mounting them bad boys up
    Towing my buddy's "Suburbasaurus" (Rockwell equipped 'burban) to his new digs
    Hopefully, that's about it!
    John
  7. 87GMCJimmy
    Nov 21, 2001
    582
    Phoenix, AZ
    Haha! I'm not looking forward to hanging out in the 110+ degree garage but it has to be done! I need to get some type
    of coolor for it!
  8. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    My options for what I should (need to) do:
    1) Pull tranny and T-case out of '74 truck
    2) Put tranny and T-case in '85 truck
    3) Put transfer case in '78 Truck
    4) Replace tie rod on little crew cab
    5) Pull T-case out of big crew cab
    6) Repair cracked frame on Utility truck
    7) Put rear lift blocks under camouflage blazer
    8) Start disassembling '75 Blazer
    9) Replace clutch disc in "truck-blazer"
    Or...take my last operating vehicle and drive around exploring the backroads.
  9. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Nothing this weekend. The Blazer is in the shop getting the engine swapped and I'm leaving for Charlotte. Next weekend I'm cutting the front Fenders.
  10. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Finishing up the 205 tonight after putting in the 400 input shaft, then the fun begins! The DOUBLER is finally going in this weekend! Can't wait to try it out! I have already built the doubler part of the setup with the adapter and the 203 range box, so the only thing left to do is to get it all in the truck. /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif
  11. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    Funny you should ask! I just found out that my company is shutting down. Should I work on my resume or the K5? ... Hmmmm, K5 it is! /forums/images/icons/laugh.gif /forums/images/icons/grin.gif Got a 14B FF to install and a D60 to rebuild so that should eat up my time. /forums/images/icons/smile.gif
  12. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I am like the others here..
    Pulled the 205 from behind my '71 trucks TH400.
    Put 205 into my doubler.
    Take TH350/203 from '73 Blazer.
    Take off Flexplate put in Flywheel and bushing.
    Put in sm465/203/205 in '73 Blazer.
    Measure front driveshaft length.
    Check out how slow it crawls... /forums/images/icons/smile.gif
    Take out TH400 from '71
    Put th350/203 in '71 truck.
    Fix '71 trucks oil leak.
    Get measurements for '71's driveshafts F&amp;R
    order driveshafts '73 front and '71 driveshafts.
    Sell '71 truck.
    OH YEAH!!! BUYING FIREWORKS!!!!!!!!!!
    /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/shocked.gif /forums/images/icons/tongue.gif /forums/images/icons/cool.gif
    Then I can go to RUBICON next weekend!!! (in my dreams)
  13. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Going up to Timothy Lake (up on Mt. Hood) camping..........testing out the dual battery setup with the tunes. /forums/images/icons/cool.gif
  14. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Putting on my new soft top and then I'm going to Jackpot, Nevada for two days.
  15. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I'm going junk yard hunting for 57'' springs, if I get lucky I will be installing them this weekend. /forums/images/icons/cool.gif
  16. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    1. install new speakers
    2. find short in existing speaker wiring
    3. figure out why the horn and dome lights don't work anymore
    4. rotate tires
    5. change oil
    6. drink beer /forums/images/icons/smile.gif
    7. relax
  17. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I will be working on 2 cases of Rolling Rock, sense it will be raining all f*cking weekend,
  18. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I has some unexpected days off this week, so I:
    a. Finished greasable rear bushing install
    b. Finished MOO engine xmember install
    c. Figured out that my rear ubolts were finger tight and that I should periodically check them
    d. Fixed more wiring on the 73
    So, that leaves this weekend (which will be a rain-out) to do the family thing.
    -- Mike
  19. Grim-Reaper
    7,385
    Atlanta
    Been installing a new frame on my utility/camper trailer last sunday and today. Hope to finish it to the point of getting this thing out of the garage. Then I can reintall the top half.
    Watching the weather right now. Papa Roach is playing On the bricks in Centianal park in Atlanta. Free concert sponsored by the local radio station. I have passes into the Nokia Hospitality tent. Read that as Free Booze and food /forums/images/icons/smile.gif It's starting to look like rain /forums/images/icons/frown.gif so still up in the air if we are going to go. Out door concerts in a thunderstorm are not much fun.
    Guy from safelite left about 2 hours ago after putting in a new windsheild in Dollar. It got busted last week when I was on my way to meet up with Krazie and the GA crew when Krazie was in town. Got to love zero deductable comprehensive /forums/images/icons/smile.gif Poor old guy that put the windshied in wasn't real thrilled when he saw the 7ft tall truck LOL He was using a step ladder to get in and out of the truck. Had to help him put the window in because it was so tall LOL. He was pretty cool once I got him loosed up. Down side is I need to get another CK5 windsheild banner ordered.
    If I have the trailler completely done Saturday then I'll get around to installing the front driveshaft in Dollar and getting my Rocker extensions cut and installed.
    Been having fun with my new Hobart handler 175. Had the thing almost a year and didn't have much of a chance time wise to do any welding projects till the past week. MAN it rocks! the new frame for the trailer has been so much easier to build with a Mig than it would have been with the stick. I'm going to have to figure out a few more projects to build /forums/images/icons/smile.gif Ohhh Depdog! what's your schedule like next week? Hmmm that Stinger you and keith built looked sexy ! /forums/images/icons/grin.gif
    I have all of next week off. Hope to get a day of wheeling in. Also need to paint the kitchen (some vacation but you got to do what you got to do).
  20. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    1. Grind my D60 calipers to fit my new 15's.
    2. Get my new 38.5x14.5x15 tsl/sx's mounted and balanced.
    3. Finish my rear brake lines.
    4. Start making some tube doors.
    5. Pop the top off of the truck.
    6. Remove the doors and interior.
    7. Bolt up the new wheels and tires.
    8. Hit the local yard for some springs, either f-150's or 3/4 56's.
    9. Pull the nose off of the truck.
    10. Install new springs in the rear.
    11. Install zero rate off set's in the rear and move the axle back 1.5"'s.
    12. I doubt I will make it to 2, but there is always hope. /forums/images/icons/grin.gif
