What are you working on this weekend?
Discussion in 'The Garage' started by zakk, Apr 11, 2003.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    We haven't done a progess report in a while, so Post up what is on the plate for the Rig this weekend.
    Me:
    Hope the 32 spline stuff comes so I can bring the 205 to the machinest
    Run tranny cooler lines
    TV Cable kickdown
    Re-install starter
    this is all in the hopes that it doesn't rain.
  2. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Well, gotta put the V8 engine mounts and crossmember in my 72 and drop the mild 350 in it like ive been trying to do for two months. My old 292 was dead after it pegged the guage at 300+ *F so it gave me a good excuse to put this beast in. like to get my new front bumper on as well.
  3. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I just came in from working on my steering... Pulled the pump to replace the fitting and mod it a little more for more pressure. Also made a bent tube filler extension and welded that on. I'm waiting for some rtv to dry right now and as soon as that happens I'll be fillingit and see what happens... Hopefully this will cure my leaking and burping problem...
    This weekend I plan to work /forums/images/graemlins/crazy.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/crewcab.gif
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Goin over to Kens to help him to build a new winch bumper and stuff
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    finish disassembly on my 454 and start block cleanup, grinding out all the casting 'boogers'
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    TEAR the 76 appart, go to PHX area to meet up with a few folks for parts swapping and stuff.
    eat a bunch and sleep a little.
    work my standard 6th day of worrk for the week.
    grant
  7. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Lets see.....Work at the shop from 7am to 9pm tomm on other people's cars. If I get time in between I need to work on my stero problem and my wiper problem. On Sunday Im puttin my shiftkit in.
  8. Donna
    Donna 1/2 ton status
    Feb 20, 2001
    2,377
    Gettysburg,Pa
    Let's see....where should I start?
    We will be installing my new lift kit....my 1 ton axels......new bumpers (well new to me).......sanding and painting numerous parts....and that's just the begining. Not sure if we will get it all done or not but we sure are gonna make a go at it.
  9. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    puttin my spare P/S pump in tonight, (waiting for my Hydro setup from WTO), help my buddy replace his Master cylinder,
    then go wheelin tommorow, to test out my buddies newly aquired, 42" tsl's, 5;13's, and F&R detroits.
  10. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Looks like Lower Proving grounds for me. /forums/images/graemlins/grin.gif
  11. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    getting my quad going tomarow, putting running lights on this weekend sometime /forums/images/graemlins/thumb.gif. already installed my old used running boards, daimond plate. loooks cool. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gifLIFTED /forums/images/graemlins/thumb.gif /forums/images/graemlins/truck.gif
  12. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Driving to Moab. Leave 8 am eastern Sat. arrive in Moab Sunday afternoon. Love that drive.
  13. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    well my plans are:
    Saturday
    8:00am arive at shop
    8:30am sand blast friend roll cage from his jeep
    9:00am start takin out my D60 and 14 bolt out from under my truck and installing a D44 and another 14 bolt with higher gears
    4:00pm..hopefully done at this point with no problems encountered
    5:00pm head home and get SSS done
    6;00pm get some dinner and then veg on the couch for awhile
    9:00 or so..head to the bar and have a few drinks
    2:30am go to bed
    sunday
    7am wake up with massive hang over...hit snoose button
    8am...roll my ass out of bed
    9am at shop
    10am.. drag rock buggy frame into shop
    10:30 try to get the placement for the links on the D60 and 14 bolt that i pulled out of the blazer on saturday
    2:00 finish welding brackets on axles for links
    5:00 clean up everything and head back home and crash
    Monday
    5:30 am wake up and do the SSS deal again
    8:00am Be in sacramento to take the Dept of corrections test..
    then from there...who knows
  14. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Try to find my elusive vibration again.Change the oil and gear lube in everything.Replace the rear wheel cylinders and check for other wore out stuff.Same as every year,just trying to get fit to do Tellico. /forums/images/graemlins/thumb.gif
  15. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I am hoping to put different (not new!) tires on the 80'
    Sand and primer the 80'
    Fix the rear window in the 80'
    Replace the rear leafs in the 80' w/ the old ones out of the 79'
    Put a new steering column in the 79'
    Put a different rear end in the 79'
    OH, yeah, and mow the yard. /forums/images/graemlins/smirk.gif
  16. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Finish fencing the backyard, get a lawnmower that's wife-friendly ( /forums/images/graemlins/thumb.gif ), and then finally work on the Burb....
    Rear brakes are shot, so I'm going to dress up a 3.21 ratio 14FF with 1-ton brakes. If I go easy on the Guinness, I should be able to get it assembled Saturday, and installed on Sunday.
  17. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Man you guys are too ambitious
    Its too nice out to work.
    I think I'll just pick up a few cold ones and go 4 wheeelin. /forums/images/graemlins/thumb.gif
  18. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    i have to see how long a chevy luv will run whith a bed bearing somewhere in the tranny. Hopefully it will last untill my f-150 is road worthy. On that note i get to fab, bumpers for my f-150 /forums/images/graemlins/laugh.gif
  19. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    My list for about the near future.
    Paint Diff covers. (Chevy Orange)
    Install Allen Head bolts on diff covers
    Install Remote Trans filter kit I picked up today.
    Install 35's ( /forums/images/graemlins/grin.gif) and trim fenders to fit them ( /forums/images/graemlins/frown.gif)
    Possibly pop the top and paint it (weather is nice too /forums/images/graemlins/laugh.gif)
    Drill Tcase skid plate for fluid drain hole.
    Press some new ujoints in spare axleshafts (2 sets)
    Press some new ujoints in spare driveshafts (f&r)
    Adjust idle mix on Qjet
    Reinstall 32's for street use /forums/images/graemlins/frown.gif
  20. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'll be shoveling gravel /forums/images/graemlins/frown.gif ,Going to rock the back side, and both ends of the trailer house where there is just dirt with small patches of grass. Be alot easier then mowing this summer. Other then that, I'll be working on grilling some T-bone steaks. /forums/images/graemlins/thumb.gif
