what are zero rates
Discussion in 'The Garage' started by jimmy1984, Feb 9, 2007.
  1. jimmy1984
    jimmy1984 1/2 ton status
    Jan 12, 2007
    153
    Napa CA/Oconomowoc WI
    ive been reading alot of threads on here and alot of people are refering to zero rates on there trucks i was just wondering what they are and what they do and if the instalation is worth it.
    thanks
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Blocks that bolt onto the spring pack for lift, usually 1 inch. They have no effect on the spring rate, hence the name.
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Correct.
    And they allow you to relocate the axle a small amount. 1/2 to 1 1/2"
  4. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    These are Zero rates, one of the Vendors on this forum sales them
    OffRoad Design
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yep, and if you mill a taper on them they're better than adding shims to correct pinion angle. I've made my own to get good level height and pinion angle. 3/8" on the front and tapered 1 1/2" on the rear.
  6. jimmy1984
    Jan 12, 2007
    153
    o ok thanks for that. so they are similar to lift blocks but alot smaller corect and can be tapered to reduce pinion angle. that might come in handy
  7. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    And unlike lift blocks, you can use zero rates in the front because it bolts to the the spring pack.
