What are.......
Discussion in 'OffRoad Design' started by speed_deed, Mar 18, 2002.
  1. speed_deed
    speed_deed 1/2 ton status
    Jun 15, 2001
    947
    Valley Center KS
    Zero rates? I have heard of ORD's Zero rates. What are they?
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    They are a 1" steel block that bolts into the spring pack w/ the center pin (insted of just being squeesed between the spring and the perch like a regular block). Because they can't be "spit out" they are safe for the front. They will give you 1" of lift and also allow you to move your axle forward or backward some if you want.
  3. speed_deed
    Jun 15, 2001
    947
    Valley Center KS
    Oh ok thanks alot.
