What attributes to dieseling?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, Feb 7, 2002.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    I have adjusted the timing and it's right at 4 above tdc. as it calls for in the manual. This is a sb400 bored .030 over. Everything is stock, no big cam etc. It has just started doing it and it's driving me nuts. What should I check?
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2>http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    possible cheap gas? did you just fill up?
    1986 K5 Blazer
    Stock and changing soon!
  3. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Carbon buildup will do that as well. Get some good gas additive and take it out for a good romp on the hiway. Good luck.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  4. kilroy
    kilroy Registered Member
    Nov 25, 2001
    85
    Alaska, Anchorage area
    Take a look at your Choke ensure it fully opens when warm, check idle mixture and look for vacuum leaks.
  5. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    Find some stuff called SeaFoam if you can. Does a great job cleaning up carbon build-up in engines.
    1984 K5 Blazer 4x4 Silverado
    6.2L diesel, 700R4, 3.42 gears, 31x10.5" tires
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Check -
    1. Idle speed. Too high will cause dieseling
    2. Timing - you have that covered. However, did you set it with the vacuum line removed and plugged? Important point.
    3. Vacuum lines - make sure you have NO vac leaks.
    4. Octane - if you put 87 in it, try 89 or 92 next time. If you had this rebuilt recently, the compression ratio might be higher than you intended (due to a thin head gasket, etc.)
    For a short term 'fix' (*not really a fix*), shut it off in gear so it won't continue to run-on.
    ONE TON</font color=blue> <font color=green>TPI'd</font color=green><font color=red> BEAST<font color=red>
  7. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Ahhh! You jogged my memory. I know I do have a pretty good vacuum leak under one side of the carb. I tightened that sucker down so much and it still sucks around the base of it. I did disconnect and plug the vacuum advance as well as turned the ideal way down. Plus the last couple of fill ups I have been going to this new cheapy gas station that just opened. I guess I need to replace the carb gasket now and stop using that gas station. You guys rock. Thanks for the tips.
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s/6superliftand33s.msnw>http://communities.msn.com/OffroadK5s/6superliftand33s.msnw</a>
