what axle for 44" tires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by madups311, Nov 15, 2001.
  1. madups311
    madups311 Registered Member
    Nov 14, 2001
    72
    VA
    what axle for 44\" tires
    Does it matter?
  2. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Re: what axle for 44\" tires
    yeah i would say it does! ask executioner this question. He has a 12 bolt front that is unbreakable!
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i would not be worried...lurk for a bit and fill out your profile so we know how to answer
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  4. lv2whl
    lv2whl 1/2 ton status
    Mar 4, 2001
    130
    CA, USA
    if you have to ask, you probably dont wheel very hard. but if you have the money, go with a dana 60 up front and a ff 14 bolt out back. or if you have alot of cash go with rockwell 2.5 tons. thats what i would do.
  5. madups311
    Nov 14, 2001
    72
    VA
    I don;t believe I will be doing much rock crawling, But i do want a strong axle for front and rear
    1979 Jimmy 4" skyjacker, add-a-leaf, 35" M/T's, Body Lift purchased.
    2001 Pathfinder LE Mile Marker Winch
  6. madups311
    Nov 14, 2001
    72
    VA
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    d60's are the strongest EASILY swapped axle available in the 4x4 world IMHO. The 14bolt full-floating axel rear is just about that strongest GM thing made, besides the allison tranny. I run both and it is about as stron as you get b4 rockwells. the set up costs atleast 1500 bones no matter where you are in the US, un less you rebuild dead ones yourself. you will also need about 12in of lift + fender trimming to fit them under your jimmy along with gears and a BB to spin the fat meats.
    -Zakk
  8. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    There's a lot more than axles for 44's
    drive angles
    power to turn the meats
    hope you're ready for a can of worms with a big pocket book
    <a target="_blank" href=http://www.whiteknight.scriptmania.com/>http://www.whiteknight.scriptma
    nia.com
    </a>
  9. madups311
    Nov 14, 2001
    72
    VA
    The 44's are a dream that i'm going to slowly make a reality,
    I'll take it one step at a time. any morew ideas welcomed
  10. Nonesuch
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    another BIG issue while running 44's.... radiator and firewall clearance. im not sure if 12" inches of lift will get you out of this mudhole!
    Justin
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My buddy has 12" + 3" body on his K10/K20. His fenders aren't even trimmed. He has rubbed a little, but no major problems.
    Tim
  12. buzzk5
    buzzk5 Registered Member
    Aug 30, 2001
    29
    gimli,mb,ca
    you can do it mads....and its lots of fun,....i put 1200r20 tires ...true 44inches tall and 11 inches
    wide, like skinny 44's,....4 inches susp lift, 4 inch body lift,..massive fender trimming, including
    front bumper tips,...you gotta get the right offset/backspace, ...i bought the tires and mod'ed
    the truck to fit them....totally happy,...still road legal,...do your profile dude,...
    Dave
    80K5 on ice
    are they all spinning?????
  13. aaaaggh
    aaaaggh 1/2 ton status
    May 4, 2001
    161
    birmingham alabama cause there no ham like birming
    one word "mog"
    would you mind un-wedging your fullsize from between those trees? your blocking the trail.
  14. Ryeguy
    Ryeguy 1/2 ton status
    Oct 30, 2000
    Victoria, B.C.
    Go Mog axles.
    --Rob
  15. madups311
    Nov 14, 2001
    72
    VA
    any ideas what size tires i can run with 4"susp and 3"body
    I will trim the hell out of the fenders If they will allow even bigger tires...Thoughts?
  16. madups311
    Nov 14, 2001
    72
    VA
  17. 1 FN HI K5
    1 FN HI K5 1/2 ton status
    Aug 7, 2001
    465
    Northern CA Out in the stick\'s
    It does matter I would change the rear axle to a dana 60 or 14 bolt. I have a 60 rear and a high pinion (reverse rotation) front dana 44 and a 60 in back because the 14 bolt sticks down to low.I am running 44's under my blazer with no fender trimming.<font color=red>1 FN HI K5</font color=red>
    <a target="_blank" href=http://community.webshots.com/user/1fnhik5>http://community.webshots.com/user/1fnhik5</a>
  18. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I would say a 4+3 and trimming would let you have 38's to 39.5's depending on the amount of triming and how much flex you want
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  19. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    You could get 39.5s in there with fender trimming for sure. What mag was it that had the Blazer with 39.5s and only 4" of sus lift? I forget, but with some serious fender trimming lots of things are possible. ;) I'm gonna take the sawzall to mine to fit a nice set of 37s in there. 8)
    J
    See the on-going build up of my '85 Jimmy! http://community.webshots.com/user/jekbrown
  20. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    44x11 inch tires. That sounds excellent. What kind of tread if that? Pictures of the tires, tires and your truck? Etc.
    Ken H.
    '86 K5 up and coming
    14 bolt(Detroited),10 bolt,39.5 Boggers rear,
    TSLs front, 468 BBC, 350 trans, 205 transfer
    Rust free in Michigan!
