What axle is it?!?!?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cavalry, Nov 6, 2001.
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I found a axle today in the junkyard while on break....I was looking for another D44 8 lug for my rig and spotted this laying in the back of a toyota with a matching 14 bolt...The hub is much bigger than the ones I currently have (about 4.56") but the spring perches are 31 3/4" like my D44. And has a simmilar cover pattern to a D44 I really dint have much time to check the inside out. I will try to get a pic up tonight, I am not sure how much they will show though.
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  2. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    Sounds like a pre '77 D44. They have the big hubs.
    '79 K5, '79 Suburban, '76 Br**co, 77 K20
    '99 BB 4x4 Suburban to tow more junk home
  3. Cavalry
    Oct 1, 2000
    978
    I also found a '73? D44 there with 3.57" hubs ....
    Luke
    84 K5
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The easiest way to ID a Dana 60 is by the 4 bolts, in a square pattern that hold the steering arm in place. (It's 3 bolts in a sort of arc pattern on a 44 or 10-bolt).
  5. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    I'm with you Harry, sounds like it might be a 60. If it is you better snatch it up before someone else does. I found a 1 ton 4x4 Army ambulance this weekend in a wrecking yard, but the owner said it belongs to the local DEA and they won't sell it. Man you just don't know how excited I got when I noticed that thing sitting there under those trees! What a shame that they would rather let it sit and rot than let someone get some use out of it! By the way, it has 8Koriginal miles!
    '85 K5 : Run it til it breaks, then fix it and go again!
  6. Cavalry
    Oct 1, 2000
    978
    I guess I will go back and look at it again tomorrow....already talked to the boneyard owner...regardless if whatever it is its mine for $100 hehehe
    Luke
    84 K5
