what axle is it
Discussion in 'The Garage' started by luk3, May 9, 2002.
  1. luk3
    luk3 1/2 ton status
    Apr 29, 2002
    108
    idaho, USA
    i was wondering what axle was on my 73 2wd 3/4 gmc high seirra, im thinking its a big axle since the springs in the rear are really heavy duty and stiff. I would also like to know if this axle is any good for 4x4. thank you
  2. 82GMC
    82GMC 1/2 ton status
    May 14, 2000
    553
    Seattle Washington
    It'll be a 14 bolt FF if it's stock. It is a very good axle for 4x4's because of it's a very strong axle!! It will handle 44's with ease/forums/images/icons/cool.gif. Look in the axle ID chart in the technical section of this site, For some photo id.
  3. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    My uncle has a 69 3/4 ton GMC pickup. It doesn't have a 14FF, It has a D60 or eaton 3/4 ton, not sure.
  4. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    73 and later, like his, it'll be a 14FF.
  5. luk3
    luk3 1/2 ton status
    Apr 29, 2002
    108
    idaho, USA
    would the stock axles be fine for 35s or 36s tires on second gen k5s? would the axle be an easy to put on a k5? or require alot?
  6. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    a 69 most likely has an eaton
    Later
